BenQ MS527 3300 Lumens DLP Projector SVGA
Quicklinx: C9P7WS00 Mfr#: 9H.JFA77.13E
Portability: Portable
More than 50 in stock
£216.56 ex VAT
£259.87 inc VAT
Offering lower TCO and optimized projection through dynamic power saving, uncompromised brightness, exquisite picture quality and optimized lamp life-SmartEco Technology has perfected what a DLP projector can do. With this innovation, schools and corporates are able to save up to 70% of lamp power consumption and lower maintenance costs through dynamic power saving features while bringing an ultra-vivid viewing experience into every presentation.
  • Lampsave mode
    Projector lamp replacement costs make up the biggest part of the total cost of projector ownership. The LampSave Mode is designed to adjust the lamp power dynamically by content brightness level to extend projector lamp life significantly by 50%! The lamp replacement frequency is also reduced by up to 50% to lower the replacement costs.
  • Blu-ray Full HD 3D Supported
    BenQ MS527 is built with latest DLP technology to support 3D functionality, allowing schools to bring an immersive learning experience to their students with a simple preparation of 3D glasses and 3D content from your blu-ray player.
  • BenQ DLP projectors perfectly long lasting picture quality with DLP Projection Technology
    Digital Light Processing (DLP), awarded 2015 Academy Award of Merit (Oscar statuette), is the leading projection technology used in 90% of world's digital cinemas and 100% of IMAX theaters. With DLP dominating the worldwide projector market with over 50% share, BenQ is today the bestselling DLP projector brand, delivering unmatched world-class performance.
  • Long lasting
    The incredibly durable micro-mirrors of the DLP chip and the nearly-sealed DLP engine design mean that BenQ DLP Projectors stand the test of time without any loss in picture quality. Eliminating dust buildup and heat damage, BenQ projectors shine year after year and look as good as new with a simple lamp change.
  • Razor-sharp
    Critically acclaimed for industry-leading high contrast, BenQ DLP Projectors also produce the most crisply defined sharpness for crystal-clear details and legible text by maximizing the fill ratio of individual pixels and employing exclusive BenQ SmartEco Technology.
BenQ MS527 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3300 ANSI lumens
Contrast Ratio
13000:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 4500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
270 Watt
28.3 cm x 22.2 cm x 9.5 cm
1.9 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3300 ANSI lumens
Contrast Ratio
13000:1
Image Size
152 cm - 762 cm
Throw Ratio
1.96 - 2.15:1
Resolution
SVGA - SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
sRGB colour profile, ecoFACTS, SmartEco Technology, Dynamic Mode, SmartEco Mode, LampSave Mode
Lens
Lens Aperture
F/2.56-2.68
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
Remote control
1 x VGA cable
Security Features
Security Slot Type
Kensington security slot
Nominal Voltage
270 Watt
Power Consumption Stand by
0.5 Watt
28.3 cm
22.2 cm
9.5 cm
1.9 kg
Sound Emission
33 dBA
28 dBA
C9P7 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.87
C9P7 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.17
C9P7 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.44
Brand: BenQ
Price Range Ex VAT: 150 - 300
