BenQ MONITOR 17" LED
Quicklinx: 9962WS00 Mfr#: 9H.LARLB.Q8E
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: [N/A]
Interfaces: VGA (HD-15)
Hurry, only 1 left in stock!
£97.88 ex VAT
£117.45 inc VAT
With the BL702A Flicker-free LED backlight panel, an ultra-high dynamic contrast ratio of 120,000:1, and BenQ's exclusive Senseye technology to offer you the best viewing quality at all times. The BenQ BL702A is designed with computer ergonomics in mind to add comfort and flexibility to your everyday work - boosting productivity and efficiency at the same time!
  • Flicker-free backlight for visual pleasure
    The BL702A is upgraded to eliminate flickering at all brightness levels, effectively reducing eye fatigue. The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but can certainly feel them. Free your eyes from flickers by switching to Flicker-free monitors and let your eyes do less work.
  • Low blue light mode
    Every monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique low blue light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. Switch to one of the four preset low blue light modes from OSD hot key, and reward your eyes without having to lose the visual enjoyment.
  • Senseye 3 visual solution to your everyday viewing needs
    Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and ECO - with the ECO mode especially design to save power and money.
  • 12M:1 DCR for depth and definition
    The BL702A comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance.
BenQ BL702A - BL Series - LED monitor - 17"
LED-backlit LCD monitor - 17"
Panel Type
TN
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Input Connectors
VGA
Environmental Standards
ENERGY STAR Qualified
TUV, GS, TCO Displays 6.0
Display Type
Diagonal Size
17"
Panel Type
TN
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, colour temperature, phase
Senseye 3 Technology
VGA
Mechanical
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Security Slot Type
Kensington security slot
Power Supply
Internal
AC 120/230 V
17 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
- weight: 2.5 kg
ENERGY STAR Certified
Limited warranty - replacement - 2 years - on-site
5 °C
20 - 90% (non-condensing)
BenQ MONITOR 17 Bundle deal on BenQ MONITOR 17" LED
£197.64
9962 C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE In Stock £10.34
9962 C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable In Stock £11.60
9962 C2G VGA to Composite PC-TV Video Adapter In Stock £33.65
Diagonal Size: 17in
Response Time: 5ms
Speakers: [N/A]
Brand: BenQ
Price Range Ex VAT: 50 - 100
