The GW2870H VA LED monitor brings viewing pleasure to everyday work and play with great details on the exterior and striking visual performance delivered by high contrast ratio, wide viewing angle, dual HDMI and sleek design.
- BenQ GW2870H - LED monitor - Full HD (1080p) - 28"
- LED-backlit LCD monitor - 28"
- Energy Class
- Class B
- Energy Consumption per Year
- 49 kWh
- Power Consumption (On mode)
- 34 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.32 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- 2xHDMI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Black texture, glossy black
- 65.9 cm x 20.4 cm x 47.7 cm
- 5.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class B
- 49 kWh
- Diagonal Size
- 28"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.32 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- HDCP, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, ecoFACTS Label, Advanced Frame Rate Control (AFRC), 8-bit gamma, 72% NTSC colour gamut
- 65.9 cm x 20.4 cm x 47.7 cm - with stand
- 5.5 kg
- VGA , 2 x HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 34 W
- Power Consumption (Typical)
- 27 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - width: 65.9 cm - depth: 5.4 cm - height: 38.1 cm
Sustainability Information
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
