BenQ GW2780 27" frameless monitor combines ultra slim bezels with hidden cable management. Complementing BenQ exclusive Eye-Care™ Technology with Low Blue Light Technology and Flicker-Free performance for extended viewing comfort, industry-leading Brightness Intelligence Technology delivers exquisite details in any ambient lighting environment.
Streamlined productivity & simplified lifestyle
Designed for beautiful simplicity, BenQ GW2780 27" frameless monitor combines ultra slim bezels with hidden cable management. Complementing BenQ exclusive Eye-Care technology with Low Blue Light and Flicker-Free performance for extended viewing comfort, Brightness Intelligence technology delivers exquisite details in any ambient lighting environment. With the ideal combination of LED and IPS technologies, GW2780 delivers a high level of visual enjoyment with truly authentic colors, deeper blacks, higher contrast, and sharper details. -
Ultra slim bezel design
GW2780 offers a visually spectacular edge-to-edge panel with ultra slim bezels and elegant profile that beautifully complements any modern decor. -
Cable management system
Invisible cable management system neatly hides all wires inside the monitor stand for clean look. -
IPS wide viewing angle technology
IPS technology ensures accurate color and image reproduction from any angle. Expansive 178° horizontal and vertical viewing angles ensure uniform viewing for multiple people in the room. -
Brightness Intelligence technology optimizes display performance for work and play, protecting your vision with superb image quality. -
Eliminate eye strain in any ambient light
Brightness Intelligence technology monitors ambient light in your viewing environment and actively adjusts screen brightness for comfortable viewing experience. -
Low Blue Light technology
Proprietary BenQ Low Blue Light technology filters out hazardous blue light, effectively reducing eye fatigue and irritation. -
Flicker-Free technology
Exclusive BenQ Flicker-Free technology eliminates the harmful flicker of traditional LCDs to prevent fatigue and vision damage.
- BenQ GW2780 - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A+
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 23 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 8 ms (typical); 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Black
- 61.2 cm x 18.3 cm x 46.3 cm
- 4.85 kg
- Environmental Standards
- TCO Certified Displays 7, TCO Certified Displays 8, ENERGY STAR Qualified
- TUV Bauart, DisplayPort 1.2, HDCP 1.4
- 2-year warranty
- Display Type
- Energy Class
- Class A+
- 34 kWh
- 23 W
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Pixel Per Inch
- 82
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- OSD Languages
- Hungarian, Czech, Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Arabic, Romanian, Japanese, Chinese, Korean
- Cable management cover, Advanced Motion Accelerator (AMA) technology, Low Blue Light Mode, Flicker Free technology, Ultra Slim Design Bezel, Bright Intelligence (B.I.), Eye-Care Technology
- Black
- 61.2 cm x 18.3 cm x 46.3 cm - with stand
- 4.85 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- HDMI , VGA , DisplayPort , Audio line-in , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 61.2 cm - depth: 18.3 cm - height: 46.3 cm - weight: 4.85 kg , Without stand - width: 61.2 cm - depth: 5 cm - height: 38.1 cm
- Shipping Weight
- 6.5 kg
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 2 years - pick-up and return
- 5 °C
- 40 °C
- 20 - 90%
