BenQ GW2765HT 27" 2560x1440 8ms DVI HDMI DisplayPort IPS LED Monitor
Quicklinx: B220WS00 Mfr#: 9H.LCELA.TBE
The 27" BenQ GW2765HT QHD(WQHD) IPS monitor delivers the best view for home entertainment and the highest productivity for office work with the finest precision in each and every detail. With the eye-friendly Low Blue Light technology, this stunning display not only makes a perfect investment for your visual pleasure but also for your eye health.
  • Viewing enjoyment
    The idea of creating the perfect everyday monitor that meets your viewing needs for work and play is what created the GW2765HT. From the 27" extra big screen and 2560x1440 QHD(WQHD) high resolution to BenQ's advanced IPS technology, 100% sRGB Screen technology and HDMI multimedia interface, the GW2765HT is built to amaze your eyes with the finest detail precision and the most lifelike colors from virtually every angle whether you're enjoying the latest movie or reviewing documents from work. What's more, it's got the unique Low blue light design and Flicker-free technology to keeps your eye at ease for longer viewing comfort and enhanced productivity!
  • Great color monitor with IPS technology panel
    With the BenQ's advanced IPS Technology panel and 100% sRGB screen technology, every color is delivered with the finest precision in every detail and at every possible viewing angle. Get and share a professional viewing experience.
  • 27" big screen and 2560x1440 QHD (WQHD) high resolution
    With a 2560x1440 QHD (WQHD) resolution you can enjoy over 77% more work space and higher ppi compared to conventional 1920x1080 FHD monitors. Having the extra working space means less scrolls for zooming in and out, and the higher ppi gives you a sharper and more precise viewing experience.
  • Flicker-free backlight for visual pleasure
    The GW2765HT is upgraded to eliminate flickering at all brightness levels, effectively reducing eye fatigue. Test your computer monitor for flickering:
  • Low blue light
    Every monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low blue light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. Switch to one of the four preset Low blue light modes from OSD hot key and reward your eyes without having to lose the visual enjoyment.
  • Ergo monitor
    An extensive range of monitor adjustments - height, tilt, pivot, stroke and swivel - tailor your own unique working station that is best suited for your height and viewing habits with a maximum 130mm distance between the screen bottom and the base.
BenQ GW2765HT - LCD monitor - 27"
LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
70 kWh
Power Consumption (On mode)
48 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Height, swivel, tilt
64.1 cm x 22.4 cm x 55.5 cm
6.9 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
LCD monitor / TFT active matrix
Energy Class
Class C
70 kWh
48 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Controls & Adjustments
Colour temperature
HDCP, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Flicker Free technology, Ultra-Flexible Height Adjustment System (HAS)
6.9 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D , VGA , Headphones , HDMI , DisplayPort , Audio line-in
Mechanical
VESA Mounting Interface
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable - 1.5 m , 1 x DisplayPort cable - 1.5 m , 1 x HDMI cable - 1.5 m
Security Slot Type
Kensington security slot
Power Supply
Internal
AC 90 - 264 V
32 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
ENERGY STAR Certified
B220 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
B220 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.34
B220 C2G 5m Select High Speed HDMI with Ethernet In Stock £21.17
