From the big screen and high resolution to BenQ's advanced IPS technology and HDMI multimedia interface, the GW2765HE is built to amaze your eyes with fine detail precision and lifelike colors from virtually every angle whether you're enjoying movies or reviewing documents from work.
Simply designed
GW60 series blends perfectly with any décor, adding a hint of low-key elegance to your living space with its high-gloss frame and base stand streamlined by a curvaceous neck that creates stunning visual fluidity. Beautiful from any angle, the back of the GW2765HE recreates the powerful drive of a racing car. -
High resolution
Incredible resolution offers extraordinary clarity of fine details and depth of subtle textures optimized for gorgeous picture quality. -
Eye-care technology
BenQ exclusive eye-care technologies reduce eye fatigue for user comfort, enhanced productivity, and workplace safety during extended use. -
Low blue light technology
Unique BenQ low blue light technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation. -
Flicker-free monitor
Flicker-free technology eliminates flickering at all brightness levels and reduces eye fatigue effectively. Relieve your eyes from the uncomfortable flickering effect by switching to a BenQ flicker-free monitor.
- BenQ GW2765HE - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey), 12 ms (tr - tf)
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Height, swivel, tilt
- Voltage
- AC 120/230 V
- Glossy black
- 64.1 cm x 5.6 cm x 37.9 cm
- 6.9 kg
- Display Type
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Flicker Free technology, ecoFACTS Label
- Glossy black
- 6.9 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- DVI , HDMI , VGA , Audio line-in , Headphone input , DisplayPort
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 320
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - 1.5 m , 1 x HDMI cable - 1.5 m , 1 x DisplayPort cable - 1.5 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 55 Watt
- Power Consumption Stand by
- 0.5 Watt
