Product
Brand
BenQ GW2765HE 27" 2560x1440 4ms VGA DVI HDMI DisplayPort IPS LED Monitor with Speakers
Quicklinx: DBZ2WS00 Mfr#: 9H.LFMLA.TBU
From the big screen and high resolution to BenQ's advanced IPS technology and HDMI multimedia interface, the GW2765HE is built to amaze your eyes with fine detail precision and lifelike colors from virtually every angle whether you're enjoying movies or reviewing documents from work.
BenQ GW series GW2765HE - LED monitor - 27"
LED-backlit LCD monitor - 27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
12 ms (tr - tf); 4 ms (gray-to-gray)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Glossy black
64.1 cm x 5.6 cm x 37.9 cm
6.9 kg
Display Type
Diagonal Size
27"
Viewable Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Flicker Free technology, ecoFACTS Label
Glossy black
6.9 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
DVI , HDMI , VGA , Audio line-in , Headphone input , DisplayPort
Mechanical
Tilt Angle
-5/+20
Swivel Angle
320
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - 1.5 m , 1 x HDMI cable - 1.5 m , 1 x DisplayPort cable - 1.5 m
Security Slot Type
Kensington security slot
AC 120/230 V
55 Watt
Power Consumption Stand by
0.5 Watt
