Built to bring you the ultimate personal visual entertainment, the BenQ GW2760HS is certainly one of a kind! Featuring the slim bezel, flicker-free backlight, speakers, 3000:1 native contrast, 20M:1 dynamic contrast ratio, and true 8-bit panel performance with deep blacks and minimized light leakage, this VA LED monitor refreshes your view with truly fantastic colors and details. It also gives you optimal eye comfort with BenQ's exclusive eye-caring technolog. The HDMI connectivity leads the path to a whole level of multimedia enjoyment.
Fashionably slim for your viewing pleasure
Exceptionally built to please your eyes with fantastic colors and details from every viewing angle, as well as a beautiful slim design, the GW2760HS Full HD VA LED monitor is everything you'll need for essential home and office use and more! Get ready to enjoy luxury premium visual enjoyment everyday with BenQ! -
Slim and beautiful with more to please the eye
A stunning work of art, the GW2760HS is fashioned with a slim bezel and slim chassis to create a simple, compact look that complements every contemporary home and office. A slim bezel design not only saves space but also enables a nearly seamless view in multi-display configurations. -
Flicker-free backlight for visual pleasure
The GW2760HS is upgraded to eliminate flickering at all brightness levels, effectively reducing eye fatigue. -
Reading mode for an optimized reading experience
For a more comfortable reading experience, BenQ has adjusted the monitor's color temperature, brightness, contrast ratio and sharpness to create the reading mode which simulates the look of printed paper to help reduce the eye discomfort typically caused by prolonged and focused use of eyes on computer monitors. -
Improved eco mode for higher energy efficiency
The improved eco mode adjusts the backlight brightness level to ensure the highest display quality is presented to you with the highest energy efficiency. This intelligent mode reduces at least 37% of the power consumed by document viewing, Internet browsing and emailing and up to 44% of the power consumed by gaming. -
3000:1 native contrast ratio and 20M:1 dynamic contrast ratio for depth and definition
The GW2760HS comes with an ultra-high native contrast ratio of 3000:1 and dynamic contrast ratio of 20M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. -
Color Shift-free technology
Enjoy perfect skin tone and image color presentation from a wide-viewing angle of 178°/178°! The Color Shift-free technology reduces the visibility of color washout, or color shift, between normal and oblique viewing angles, giving you consistent color uniformity and true color definition from left, right, above and below. -
Perfecting your audiovisual enjoyment with speakers
Whether you're listening to music or watching your favorite film, simply turn on the speakers to experience the audiovisual fun! -
HDMI multimedia interface
The HDMI high-speed multimedia interface makes these monitors incredibly convenient to use - now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future. -
Full HD 1080p 16:9 visual perfection
The BenQ GW2760HS supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing. -
Superior response time
Enjoy high dynamic videos without ghosting or other artifacts with 4 ms GTG response time. -
Senseye 3 visual solution to your everyday viewing needs
Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its pre-set viewing modes - standard, movie, game, photo, sRGB, reading, and eco - with the eco mode especially designed to save power and money.
- BenQ GW2760HS - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 56 kWh
- Power Consumption (On mode)
- 38 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (47 - 63 Hz)
- Glossy black
- 70.2 cm x 13.1 cm x 44.6 cm
- 4.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- TUV
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 56 kWh
- Diagonal Size
- 27"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, colour temperature, phase
- HDCP, Senseye 3 Technology
- Glossy black
- 4.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- Audio line-in , HDMI (HDCP) , DVI-D (HDCP) , VGA , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable
- TUV
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 38 W
- Power Consumption (Typical)
- 27 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - on-site
- 5 °C
- 40 °C
- 20 - 90% (non-condensing)
