BenQ GW2480 23.8" frameless monitor combines ultra slim bezels with hidden cable management. Complementing BenQ exclusive Eye-Care™ Technology with Low Blue Light Technology and Flicker-Free performance for extended viewing comfort, industry-leading Brightness Intelligence Technology delivers exquisite details in any ambient lighting environment.
Streamlined productivity & simplified lifestyle
Designed for beautiful simplicity, BenQ GW2480 23.8" frameless monitor combines ultra slim bezels with hidden cable management. Complementing BenQ exclusive Eye-Care technology with Low Blue Light technology and Flicker-Free performance for extended viewing comfort, Brightness Intelligence technology delivers exquisite details in any ambient lighting environment. With the ideal combination of LED and IPS technologies, GW2480 delivers a high level of visual enjoyment with truly authentic colors, deeper blacks, higher contrast, and sharper details. -
IPS wide viewing angle technology
IPS technology ensures accurate color and image reproduction from any angle. Expansive 178° horizontal and vertical viewing angles ensure uniform viewing for multiple people in the room. -
Brightness Intelligence technology optimizes display performance for work and play, protecting your vision with superb image quality. -
Picture perfect content optimization
Brightness Intelligence technology detects content intensity to avoid overexposure of bright scenes while enhancing dark areas to maintain clear visibility. -
Eliminate eye strain in any ambient light
Brightness Intelligence technology monitors ambient light in your viewing environment and actively adjusts screen brightness for comfortable viewing experience. -
Flicker-Free technology
Exclusive BenQ Flicker-Free technology eliminates the harmful flicker of traditional LCDs to prevent fatigue and vision damage.
- BenQ GW2480 - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class A
- Energy Consumption per Year
- 30 kWh
- Power Consumption (On mode)
- 21 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Black
- 54 cm x 17.5 cm x 42 cm
- 3.84 kg
- Environmental Standards
- TCO Certified Displays 7, TCO Certified Displays 8, ENERGY STAR Qualified
- Display Type
- Energy Class
- Class A
- 30 kWh
- 21 W
- Diagonal Size
- 23.8"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- OSD Languages
- Hungarian, Czech, Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Arabic, Romanian, Japanese, Chinese, Korean
- HDCP, 72% colour gamut, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, Bright Intelligence (B.I.)
- Black
- 54 cm x 17.5 cm x 42 cm - with stand
- 3.84 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- Headphone input , HDMI , DisplayPort , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable
- Backlight Life
- 30,000 hours
- MTBF
- 60,000 hour(s)
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V
- 27 Watt
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 54 cm - depth: 17.5 cm - height: 42 cm - weight: 3.84 kg , Without stand - width: 54 cm - depth: 5 cm - height: 34 cm - weight: 3.04 kg
- ENERGY STAR Certified
- TCO Certified
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£233.18
