Product
BenQ GW2470HM 24" 1920 x 1080 4ms HDMI DVI-D LED Monitor
Quicklinx: CNQJWS00 Mfr#: 9H.LEYLA.TBE
A perfect embodiment of The Bauhaus' "less is more" minimalism design philosophy, the GW2470HM is a delightful complement to almost any modern space. Every aspect of its form and feature is reduced to unify simplicity and functionality into pure aesthetics. On top of it all, users get to enjoy the sheerest visual pleasure and optimal eye comfort with BenQ's exclusive eye-caring technology. The GW2470HM is not only a celebration of minimalist lifestyle and modern sleekness but also the gateway to everyday enjoyment for leisure and business.
Exquisitely refined to complement your home and office, every detail of the GW2470HM exemplifies the highest craftsmanship. The T-shaped base surface in the front is brushed with hairline treatment and adorned by a rectangular-shaped glossy black embellishment. The housing styled in black is fashioned with delicate patterns in the back to subtly catch the eye. With this classic minimalistic wonder, the GW2470HM is everything you seek for the ultimate sophistication.
  • Everyday enjoyment for leisure and business
    A perfect embodiment of The Bauhaus’ “less is more" minimalism design philosophy, the GW2470HM is a delightful complement to almost any modern space. Every aspect of its form and feature is reduced to unify simplicity and functionality into pure aesthetics. On top of it all, users get to enjoy the sheerest visual pleasure and optimal eye comfort with BenQ’s exclusive eye-caring technology. The GW2470HM is not only a celebration of minimalist lifestyle and modern sleekness but also the gateway to everyday enjoyment for leisure and business.
  • Designed simply for the ultimate sophistication
  • TÜV Rheinland Certification
    GW2470HM Eye-care monitor has been certified by TÜV Rheinland for Flicker-free and low blue light, the world’s leading provider of technical, safety and certification services, as truly friendly to the human eye. BenQ, the first brand of Eye-care monitor in the world, as a permanent addition to monitor product line, stressing on commitment to safeguard eye vision and to always act first on offering the most comfortable and enjoyable viewing experience.
  • Flicker-free backlight for visual pleasure
    The Flicker-free Technology eliminates flickering at all brightness levels and reduces eye fatigue effectively. Conventional LCD screens flicker at the rate of 200 times per second. Your eyes may not see the flickers but they can certainly feel them. So relieve your eyes from the uncomfortable flickering effect by switching to a BenQ Flicker-free monitor.
  • Low Blue light
    Unique BenQ Low Blue Light Technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation.
  • 3000:1 native contrast ratio for color depth and definition
    An ultra-high native contrast of 3000:1, which is three times of that of general panels, adds astonishing color depth and definition to darkened, complex images with the greatest subtlety and clarity. With a native contrast ratio this high, you can expect an infinite dynamic contrast ratio that far exceeds your expectations.
BenQ GW2470HM - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
16 ms (tr - tf); 4 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Textured black, glossy black
55.3 cm x 18.912 cm x 42.51 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
TUV, TCO Displays 6.0
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
23.8"
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Eco-Mode, Advanced Motion Accelerator (AMA) technology, 72% NTSC colour gamut, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, Colour Temperature Selection
55.3 cm x 18.912 cm x 42.51 cm - with stand
4.1 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
DVI , HDMI , VGA , Audio line-in
1 x VGA cable - 1.5 m , 1 x HDMI cable - 1.5 m
Backlight Life
30,000 hours
MTBF
60,000 hour(s)
Security Slot Type
Kensington security slot
AC 120/230 V
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 55.3 cm - depth: 18.912 cm - height: 42.51 cm - weight: 4.1 kg , Without stand - width: 55.3 cm - depth: 5.05 cm - height: 32.94 cm
ENERGY STAR Certified
CNQJ StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
CNQJ StarTech.com Articulating Monitor Arm In Stock £101.86
CNQJ StarTech.com Dual Monitor Stand In Stock £69.36
CNQJ StarTech.com Cubicle Monitor Hanger In Stock £45.29
CNQJ StarTech.com TV/Monitor Arm - Wallmount In Stock £65.34
