Everyday enjoyment for leisure and business! The GW2470HM monitor with eye-care design brings viewing pleasure to work and play with exquisite details on striking visual performance.
A perfect embodiment of The Bauhaus' "less is more" minimalism design philosophy, the GW2470HE is a delightful complement to almost any modern space. Every aspect of its form and feature is reduced to unify simplicity and functionality into pure aesthetics. On top of it all, users get to enjoy the sheerest visual pleasure and optimal eye comfort with BenQ's exclusive eye-caring technology. The GW2470HE is not only a celebration of minimalist lifestyle and modern sleekness but also the gateway to everyday enjoyment for leisure and business. -
Designed simply for the ultimate sophistication
Exquisitely refined to complement your home and office, every detail of the GW2470HE exemplifies the highest craftsmanship. The T-shaped base surface in the front is brushed with hairline treatment and adorned by a rectangular-shaped glossy black embellishment. The housing styled in black is fashioned with delicate patterns in the back to subtly catch the eye. With this classic minimalistic wonder, the GW2470HE is everything you seek for the ultimate sophistication. -
Flicker-free backlight for visual pleasure
The Flicker-free Technology eliminates flickering at all brightness levels and reduces eye fatigue effectively. Conventional LCD screens flicker at the rate of 200 times per second. Your eyes may not see the flickers but they can certainly feel them. So relieve your eyes from the uncomfortable flickering effect by switching to a BenQ Flicker-free monitor. -
Better eye protection with Low Blue Light modes
Every Monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows healthier time spent in front of your computer. Switch to one of the four preset Blue Light Modes (Multimedia - 30%, Web-browsing - 50%, Office - 60%, Reading - 70%; ) and reward yours eyes without having to lose the visual enjoyment. -
3000:1 native contrast ratio for color depth and definition
An ultra-high native contrast of 3000:1, which is three times of that of general panels, adds astonishing color depth and definition to darkened, complex images with the greatest subtlety and clarity. With a native contrast ratio this high, you can expect an infinite dynamic contrast ratio that far exceeds your expectations. -
True 8-bit color performance
An 8-bit VA panel delivers smoother and more stable color transitions by rendering a total of 16.7 million color shades simultaneously. A 6-bit panel with Advanced Frame Rate Control (AFRC) requires interpolation to display the same number of colors as a true 8-bit panel does. -
178°/178° wide-viewing angles
VA panels bring truly authentic colors and ultra-sharp details from left, right, above and below to your eyes with a wide-viewing angle of 178°/178°. Viewing, as you know it, will never be the same. -
HDMI multimedia interface
An HDMI high-speed multimedia interface makes these monitors incredibly convenient to use - now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future.
- BenQ GW2470HE - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class B
- Energy Consumption per Year
- 39 kWh
- Power Consumption (On mode)
- 27 W
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- 2xHDMI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Textured black, glossy black
- 55.3 cm x 18.9 cm x 42.5 cm
- 4 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV Rheinland
- Display Type
- Energy Class
- Class B
- 39 kWh
- Diagonal Size
- 23.8"
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, ecoFACTS Label, Mercury free, 8-bit gamma, 72% NTSC colour gamut
- 55.3 cm x 18.9 cm x 42.5 cm - with stand
- 4 kg
- 2 x HDMI (HDCP) , VGA (HD-15) , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x HDMI cable
- TUV Rheinland
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 27 W
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- No
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- Dimensions & Weight Details
- Without stand - width: 55.3 cm - depth: 5.1 cm - height: 32.9 cm , With stand - width: 55.3 cm - depth: 18.9 cm - height: 42.5 cm - weight: 4 kg
Sustainability Information
- ENERGY STAR Certified
