BenQ GW2406Z 24" 1920x1080 5ms HDMI DisplayPort LED Monitor
Quicklinx: CNQLWS00 Mfr#: 9H.LFDLA.TBE
The GW2406Z IPS LED monitor with 178°/178° wide viewing angles brings uncompromising image quality and visual performance for your eyes.
  • Everyday enjoyment for leisure and business
    The GW2406Z is a delightful complement to almost any space. Every aspect of its form and feature is reduced to unify simplicity and functionality into pure aesthetics. On top of it all, users get to enjoy the sheerest visual pleasure and optimal eye comfort with BenQ's eye-caring technology. The GW2406Z is not only a celebration of minimalist lifestyle and modern sleekness but also the gateway to everyday enjoyment for leisure and business.
  • Wide viewing angle with IPS technology
    With IPS technology, you see accurate color and image reproduction from any angle. An expansive 178° viewing angle is great for work and for reviewing on-screen with multiple people in the room.
  • Flicker-free
    Stable feedback technology prevents the harmful effects of flickering that strain the eyes.
  • Low Blue Light
    Unique BenQ Low Blue Light technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation.
BenQ GW2406Z - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A+
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
17 W
Adaptive-Sync Technology
VESA Adaptive-Sync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Glossy black
54.02 cm x 23 cm x 49.5 cm
3.35 kg
TCO Displays 7.0
Display Type
Energy Class
Class A+
25 kWh
17 W
Diagonal Size
23.8"
Viewable Size
23.8"
VESA Adaptive-Sync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
14 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Power off timer, HDCP, 72% colour gamut, Advanced Motion Accelerator (AMA) technology, edge-to-edge glass, Low Blue Light Mode, Flicker Free technology
Glossy black
54.02 cm x 23 cm x 49.5 cm - with stand
3.35 kg
DisplayPort , HDMI , VGA , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.5 m , 1 x HDMI cable - 1.5 m
Backlight Life
30,000 hours
MTBF
60,000 hour(s)
TCO Displays 7.0
Security Slot Type
Kensington security slot
DC 19 V
35 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 54.02 cm - depth: 23 cm - height: 49.5 cm - weight: 3.35 kg , Without stand - width: 54.02 cm - depth: 17.36 cm - height: 39.64 cm
10 - 85% (non-condensing)
CNQL StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
CNQL StarTech.com Articulating Monitor Arm In Stock £101.86
CNQL StarTech.com Dual Monitor Stand In Stock £69.36
CNQL StarTech.com Cubicle Monitor Hanger In Stock £45.29
CNQL StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
