The GW2406Z IPS LED monitor with 178°/178° wide viewing angles brings uncompromising image quality and visual performance for your eyes.
Everyday enjoyment for leisure and business
The GW2406Z is a delightful complement to almost any space. Every aspect of its form and feature is reduced to unify simplicity and functionality into pure aesthetics. On top of it all, users get to enjoy the sheerest visual pleasure and optimal eye comfort with BenQ's eye-caring technology. The GW2406Z is not only a celebration of minimalist lifestyle and modern sleekness but also the gateway to everyday enjoyment for leisure and business. -
Wide viewing angle with IPS technology
With IPS technology, you see accurate color and image reproduction from any angle. An expansive 178° viewing angle is great for work and for reviewing on-screen with multiple people in the room. -
Flicker-free
Stable feedback technology prevents the harmful effects of flickering that strain the eyes. -
Low Blue Light
Unique BenQ Low Blue Light technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation.
- BenQ GW2406Z - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class A+
- Energy Consumption per Year
- 25 kWh
- Power Consumption (On mode)
- 17 W
- Adaptive-Sync Technology
- VESA Adaptive-Sync
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 14 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Voltage
- DC 19 V
- Glossy black
- 54.02 cm x 23 cm x 49.5 cm
- 3.35 kg
- Display Type
- Energy Class
- Class A+
- 25 kWh
- Diagonal Size
- 23.8"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 14 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Power off timer, HDCP, Advanced Motion Accelerator (AMA) technology, edge-to-edge glass, Low Blue Light Mode, Flicker Free technology
- Glossy black
- 54.02 cm x 23 cm x 49.5 cm - with stand
- 3.35 kg
- DisplayPort , HDMI , VGA , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - 1.5 m , 1 x HDMI cable - 1.5 m
- Backlight Life
- 30,000 hours
- MTBF
- 60,000 hour(s)
- Security Slot Type
- Kensington security slot
- Input Voltage
- DC 19 V
- 17 W
- Power Consumption (Typical)
- 35 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 54.02 cm - depth: 23 cm - height: 49.5 cm - weight: 3.35 kg , Without stand - width: 54.02 cm - depth: 17.36 cm - height: 39.64 cm
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
