BenQ GW2283 22" 1920x1080 Full HD 5ms 2x HDMI VGA LED Monitor
Quicklinx: F5BZWS00 Mfr#: 9H.LHLLA.TBE
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: HDMI, VGA (HD-15)
£126.46 ex VAT
£151.75 inc VAT
Designed for beautiful simplicity, BenQ's GW2283 frameless monitor combines ultra-slim bezels with hidden cable management. Complementing BenQ's exclusive Eye-Care technology with Low Blue Light technology and Flicker-Free performance for extended viewing comfort, the excellent Brightness Intelligence technology delivers exquisite details in any ambient lighting environment. Built with the dream combination of LED with IPS panel, GW2283 is bound to bring a completely different visual experience and enjoyment to you with truly authentic colors, deeper blacks, higher contrast and sharper details.
  • Understated, stylish and sophisticated design
    GW2283 comes with a stylish and sophisticated design that boasts an elevated level of elegance while helping to enhance the overall productivity. Empowered by the premium etching texture and sculpted base, GW2283 resists fine scratch whirls and eliminates extraneous edges for a clean, functional appeal. Additionally, the edge-to-edge panel with ultra-slim bezels can complement any modern décor. To ensure the clean look, GW2283 offers an invisible cable management system to neatly hide all wires inside the monitor's stand.
  • IPS wide viewing angle technology
    IPS (In-Plane Switching) technology provides accurate color and image reproduction from any angle. An expansive 178° viewing angle is ideal for work and for on-screen reviews with multiple people in the room.
  • 8-bit color display
    With the ability to render 16.7 million color shades simultaneously, you can expect true colors, silky transitions and impeccable image quality.
  • Brightness Intelligence technology
    Brightness Intelligence technology optimizes display performance for work and play, protecting your vision with superb image quality. It detects content intensity to avoid overexposure of bright scenes while enhancing dark areas to maintain a clear visibility. This technology monitors ambient light in your viewing environment and actively adjusts screen brightness for the extremely comfortable viewing experience.
  • Low Blue Light
    The Proprietary BenQ Low Blue Light technology filters out hazardous blue light, effectively reducing eye fatigue and irritation.
  • Flicker-Free technology
    The exclusive BenQ Flicker-Free technology eliminates the harmful flicker of traditional LCDs to prevent fatigue and vision damage.
  • Multimedia enjoyment
    Embedded with 2 HDMI ports, users can enjoy multimedia fun by easily switching between two media sources without troublesome plug in and plug out with GW2283.
BenQ GW2283 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class F
Power Consumption (On mode)
17.7 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours (8-bit)
Colour Gamut
72% NTSC
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
48.95 cm x 18.3 cm x 39.16 cm
2.9 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
TUV Rheinland Flicker Free Certification, HDCP 1.4, TUV LBL
Display Type
Energy Class
Class F
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Arabic, Romanian, Japanese, Korean
HDCP, Advanced Motion Accelerator (AMA) technology, Flicker Free technology, K Locker, Ultra Slim Design Bezel, Eye-Care Technology, Brightness Intelligence Technology, Low Blue Light technology, 72% NTSC colour gamut
2.9 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
2 x HDMI , VGA , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
17.7 W
17.7 kWh/1000h
Power Consumption (Typical)
25 Watt
Shipping Weight
3.7 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
Diagonal Size: 22in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: BenQ
