The GW2270HM monitor with Eye-Care design brings viewing pleasure to work and play with exquisite details on striking visual performance.
Everyday enjoyment for leisure and business
A perfect embodiment of The Bauhaus' "less is more" minimalism design philosophy, the GW2270HM is a delightful complement to almost any modern space. Every aspect of its form and feature is reduced to unify simplicity and functionality into pure aesthetics. On top of it all, users get to enjoy the sheerest visual pleasure and optimal eye comfort with BenQ's exclusive eye-caring technology. The GW2270HM is not only a celebration of minimalist lifestyle and modern sleekness but also the gateway to everyday enjoyment for leisure and business. -
Designed simply for the ultimate sophistication
Exquisitely refined to complement your home and office, every detail of the GW2270HM exemplifies high craftsmanship. The T-shaped base surface in the front is brushed with hairline treatment and adorned by a rectangular-shaped glossy black embellishment. The housing styled in black is fashioned with delicate patterns in the back to subtly catch the eye. With this classic minimalistic wonder, the GW2270HM is everything you seek for the ultimate sophistication. -
Flicker-Free backlight for visual pleasure
The Flicker-Free technology eliminates flickering at all brightness levels and reduces eye fatigue effectively. Conventional LCD screens flicker at the rate of 200 times per second. Your eyes may not see the flickers but they can certainly feel them. So relieve your eyes from the uncomfortable flickering effect by switching to a BenQ Flicker-free monitor. -
Flicker-Free
Stable feedback technology prevents the harmful effects of flickering that strain the eyes. -
Low Blue Light
BenQ Low Blue Light technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation. -
3000:1 native contrast ratio for color depth and definition
An ultra-high native contrast of 3000:1, which is three times of that of general panels, adds astonishing color depth and definition to darkened, complex images with the greatest subtlety and clarity. With a native contrast ratio this high, you can expect an infinite dynamic contrast ratio that far exceeds your expectations. -
True 8-bit color performance
An 8-bit VA panel delivers smoother and more stable color transitions by rendering a total of 16.7 million color shades simultaneously. A 6-bit panel with Advanced Frame Rate Control (AFRC) requires interpolation to display the same number of colors as a true 8-bit panel does. -
178°/178° wide-viewing angles
VA panels bring truly authentic colors and sharp details from left, right, above and below to your eyes with a wide-viewing angle of 178°/178°. Viewing, as you know it, will never be the same. -
HDMI multimedia interface
The HDMI high-speed multimedia interface makes these monitors convenient to use - now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future.
- BenQ GW2270HM - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class A
- Energy Consumption per Year
- 29 kWh
- Power Consumption (On mode)
- 20 W
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey), 18 ms (tr - tf)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DVI, VGA
- Voltage
- AC 120/230 V
- Textured black, glossy black
- 50.56 cm x 17.817 cm x 40.007 cm
- 3.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV
- Display Type
- Energy Class
- Class A
- 29 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, Eco-Mode, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, Colour Temperature Selection, 72% NTSC colour gamut
- 50.56 cm x 17.817 cm x 40.007 cm - with stand
- 3.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- DVI , HDMI , VGA , Audio line-in
- Cables Included
- 1 x VGA cable
- Backlight Life
- 30,000 hours
- MTBF
- 60,000 hour(s)
- TUV
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 20 W
- Power Consumption (Typical)
- 26 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 50.56 cm - depth: 17.817 cm - height: 40.007 cm - weight: 3.6 kg , Without stand - width: 50.56 cm - depth: 5.05 cm - height: 30.42 cm
Sustainability Information
- ENERGY STAR Certified
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.67 |
StarTech.com Dual Monitor Stand | In Stock | £91.00 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £93.49 |
