BenQ GW2270HM 21.5" 1920x1080 5ms VGA DVI HDMI Monitor
Quicklinx: CJX6WS00 Mfr#: 9H.LEXLA.TBE
The GW2270HM monitor with Eye-Care design brings viewing pleasure to work and play with exquisite details on striking visual performance.
  • Everyday enjoyment for leisure and business
    A perfect embodiment of The Bauhaus' "less is more" minimalism design philosophy, the GW2270HM is a delightful complement to almost any modern space. Every aspect of its form and feature is reduced to unify simplicity and functionality into pure aesthetics. On top of it all, users get to enjoy the sheerest visual pleasure and optimal eye comfort with BenQ's exclusive eye-caring technology. The GW2270HM is not only a celebration of minimalist lifestyle and modern sleekness but also the gateway to everyday enjoyment for leisure and business.
  • Designed simply for the ultimate sophistication
    Exquisitely refined to complement your home and office, every detail of the GW2270HM exemplifies high craftsmanship. The T-shaped base surface in the front is brushed with hairline treatment and adorned by a rectangular-shaped glossy black embellishment. The housing styled in black is fashioned with delicate patterns in the back to subtly catch the eye. With this classic minimalistic wonder, the GW2270HM is everything you seek for the ultimate sophistication.
  • Flicker-Free backlight for visual pleasure
    The Flicker-Free technology eliminates flickering at all brightness levels and reduces eye fatigue effectively. Conventional LCD screens flicker at the rate of 200 times per second. Your eyes may not see the flickers but they can certainly feel them. So relieve your eyes from the uncomfortable flickering effect by switching to a BenQ Flicker-free monitor.
  • Flicker-Free
    Stable feedback technology prevents the harmful effects of flickering that strain the eyes.
  • Low Blue Light
    BenQ Low Blue Light technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation.
  • 3000:1 native contrast ratio for color depth and definition
    An ultra-high native contrast of 3000:1, which is three times of that of general panels, adds astonishing color depth and definition to darkened, complex images with the greatest subtlety and clarity. With a native contrast ratio this high, you can expect an infinite dynamic contrast ratio that far exceeds your expectations.
  • True 8-bit color performance
    An 8-bit VA panel delivers smoother and more stable color transitions by rendering a total of 16.7 million color shades simultaneously. A 6-bit panel with Advanced Frame Rate Control (AFRC) requires interpolation to display the same number of colors as a true 8-bit panel does.
  • 178°/178° wide-viewing angles
    VA panels bring truly authentic colors and sharp details from left, right, above and below to your eyes with a wide-viewing angle of 178°/178°. Viewing, as you know it, will never be the same.
  • HDMI multimedia interface
    The HDMI high-speed multimedia interface makes these monitors convenient to use - now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future.
BenQ GW2270HM - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey), 18 ms (tr - tf)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI, VGA
Voltage
AC 120/230 V
Textured black, glossy black
50.56 cm x 17.817 cm x 40.007 cm
3.6 kg
Environmental Standards
ENERGY STAR Qualified
TUV
Display Type
Energy Class
Class A
29 kWh
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Eco-Mode, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, Colour Temperature Selection, 72% NTSC colour gamut
50.56 cm x 17.817 cm x 40.007 cm - with stand
3.6 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
DVI , HDMI , VGA , Audio line-in
1 x VGA cable
Backlight Life
30,000 hours
MTBF
60,000 hour(s)
TUV
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
20 W
Power Consumption (Typical)
26 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 50.56 cm - depth: 17.817 cm - height: 40.007 cm - weight: 3.6 kg , Without stand - width: 50.56 cm - depth: 5.05 cm - height: 30.42 cm
Sustainability Information
ENERGY STAR Certified
