BenQ GW2270H 21.5" 1920x1080 5ms HDMIx2 VGA LED Monitor
Quicklinx: BPGRWS00 Mfr#: 9H.LE6LB.QBE
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: HDMI, VGA (HD-15)
Select:
More than 50 in stock
£73.18 ex VAT
£87.81 inc VAT
The GW2270H VA LED monitor brings viewing pleasure to everyday work and play with exquisite details on the exterior and striking visual performance delivered by 3000:1 high contrast ratio, 178°/178°wide-viewing angle, dual HDMI and BenQ's eye-caring design, which consists of BenQ's Flicker-free technology and Low Blue Light modes.
  • Everyday enjoyment for leisure and business
    A perfect embodiment of The Bauhaus' "less is more" minimalism design philosophy, the GW2270H is a delightful complement to almost any modern space. Every aspect of its form and feature is reduced to unify simplicity and functionality into pure aesthetics. On top of it all, users get to enjoy the sheerest visual pleasure and optimal eye comfort with BenQ's exclusive eye-caring technology. The GW2270H is not only a celebration of minimalist lifestyle and modern sleekness but also the gateway to everyday enjoyment for leisure and business.
  • Designed simply for the ultimate sophistication
    Exquisitely refined to complement your home and office, every detail of the GW2270H exemplifies the highest craftsmanship. The T-shaped base surface in the front is brushed with hairline treatment and adorned by a rectangular-shaped glossy black embellishment. The housing styled in black is fashioned with delicate patterns in the back to subtly catch the eye. With this classic minimalistic wonder, the GW2270H is everything you seek for the ultimate sophistication.
  • Flicker-free backlight for visual pleasure
    The Flicker-free technology eliminates flickering at all brightness levels and reduces eye fatigue effectively. Conventional LCD screens flicker at the rate of 200 times per second. Your eyes may not see the flickers but they can certainly feel them. So relieve your eyes from the uncomfortable flickering effect by switching to a BenQ Flicker-free monitor.
  • 3000:1 native contrast ratio for color depth and definition
    An ultra-high native contrast of 3000:1, which is three times of that of general panels, adds astonishing color depth and definition to darkened, complex images with the greatest subtlety and clarity. With a native contrast ratio this high, you can expect an infinite dynamic contrast ratio that far exceeds your expectations.
  • True 8-bit color performance
    An 8-bit VA panel delivers smoother and more stable color transitions by rendering a total of 16.7 million color shades simultaneously. A 6-bit panel with Advanced Frame Rate Control (AFRC) requires interpolation to display the same number of colors as a true 8-bit panel does.
  • 178°/178° wide-viewing angles
    VA panels bring truly authentic colors and ultra sharp details from left, right, above and below to your eyes with a wide-viewing angle of 178°/178°. Viewing, as you know it, will never be the same.
  • HDMI multimedia interface
    The latest HDMI high-speed multimedia interface makes these monitors incredibly convenient to use - now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future.
BenQ GW2270H - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
50.6 cm x 17.8 cm x 40 cm
3.4 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
Display Type
Energy Class
Class B
31 kWh
21 W
Diagonal Size
21.5"
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, 72% colour gamut, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology
50.6 cm x 17.8 cm x 40 cm - with stand
3.4 kg
2 x HDMI , VGA , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.5 m
TCO Displays 6.0
Security Slot Type
Kensington security slot
AC 90 - 264 V
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 50.6 cm - depth: 17.8 cm - height: 40 cm - weight: 3.4 kg , Without stand - width: 50.6 cm - depth: 5.1 cm - height: 30.4 cm
ENERGY STAR Certified
BenQ GW2270H 21.5 Bundle deal on BenQ GW2270H 21.5" 1920x1080 5ms HDMIx2 VGA LED Monitor
£172.35
BPGR StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
BPGR StarTech.com Articulating Monitor Arm In Stock £101.86
BPGR StarTech.com Dual Monitor Stand In Stock £69.36
BPGR StarTech.com Cubicle Monitor Hanger In Stock £45.29
BPGR StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: BenQ
Price Range Ex VAT: 50 - 100
