The 27" BenQ GL2706PQ monitor with 2560 x 1440 QHD (WQHD) resolution, with the finest precision in each detail, delivers the best view for home entertainment and the highest productivity for office work. With the eye-friendly Low Blue Light Technology, this stunning display not only makes a perfect investment for your visual pleasure but also for your eye health.
Experience premium view for the best value
The 27" BenQ GL2706PQ monitor with 2560 x 1440 QHD (WQHD) resolution, with the finest precision in each detail, delivers the best view for home entertainment and the highest productivity for office work. With the eye-friendly Low Blue Light Technology, this stunning display not only makes a perfect investment for your visual pleasure but also for your eye health. -
2K QHD monitor
QHD has over 77% working space compared with other1920x1080 FHD displays, offering stunning clarity in visuals. -
Flicker-free
Stable feedback technology prevents the harmful effects of flickering that strain the eyes. -
Low Blue Light
Unique BenQ Low Blue Light Technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation. -
Height Adjustment Stand (HAS)
The HAS allows you to find the best viewing angles for personal work or screen sharing with an extensive range of monitor adjustments.
- BenQ GL2706PQ - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 69 kWh
- Power Consumption (On mode)
- 47 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DVI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black
- 62.3 cm x 23 cm x 53.3 cm
- 6.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class C
- 69 kWh
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 43.6 - 112.6 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Low Blue Light Mode, Flicker Free technology, Colour Temperature Selection, 72% NTSC colour gamut
- Black
- 62.3 cm x 23 cm x 53.3 cm - with stand
- 6.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- DVI , HDMI , DisplayPort , Audio line-in/out , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 160
- Height Adjustment
- 120 mm
- Cables Included
- 1 x HDMI cable - 1.5 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 47 W
- Power Consumption (Typical)
- 65.7 Watt
- Power Consumption Sleep
- 0.43 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 62.3 cm - depth: 23 cm - height: 53.3 cm - weight: 6.2 kg , Without stand - width: 62.3 cm - depth: 5.7 cm - height: 37.3 cm
Sustainability Information
- ENERGY STAR Certified
StarTech.com Dual Monitor Mount - Stackable | In Stock | £227.08 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £93.49 |
StarTech.com Monitor Desk Mount - Steel | In Stock | £50.26 |
