BenQ GL2706PQ 27" 2560x1440 1ms DVI-D HDMI LED Monitor
Quicklinx: CNRWWS00 Mfr#: 9H.LFJLB.QBE
The 27" BenQ GL2706PQ monitor with 2560 x 1440 QHD (WQHD) resolution, with the finest precision in each detail, delivers the best view for home entertainment and the highest productivity for office work. With the eye-friendly Low Blue Light Technology, this stunning display not only makes a perfect investment for your visual pleasure but also for your eye health.
  • Experience premium view for the best value
  • 2K QHD monitor
    QHD has over 77% working space compared with other1920x1080 FHD displays, offering stunning clarity in visuals.
  • Flicker-free
    Stable feedback technology prevents the harmful effects of flickering that strain the eyes.
  • Low Blue Light
    Unique BenQ Low Blue Light Technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation.
  • Height Adjustment Stand (HAS)
    The HAS allows you to find the best viewing angles for personal work or screen sharing with an extensive range of monitor adjustments.
BenQ GL2706PQ - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
69 kWh
Power Consumption (On mode)
47 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
62.3 cm x 23 cm x 53.3 cm
6.2 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class C
69 kWh
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
43.6 - 112.6 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Low Blue Light Mode, Flicker Free technology, Colour Temperature Selection, 72% NTSC colour gamut
62.3 cm x 23 cm x 53.3 cm - with stand
6.2 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
DVI , HDMI , DisplayPort , Audio line-in/out , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
160
Height Adjustment
120 mm
1 x HDMI cable - 1.5 m
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
47 W
Power Consumption (Typical)
65.7 Watt
Power Consumption Sleep
0.43 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 62.3 cm - depth: 23 cm - height: 53.3 cm - weight: 6.2 kg , Without stand - width: 62.3 cm - depth: 5.7 cm - height: 37.3 cm
Sustainability Information
ENERGY STAR Certified
CNRW StarTech.com Dual Monitor Mount - Stackable In Stock £226.92
CNRW StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
CNRW StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
CNRW StarTech.com Monitor Desk Mount - Steel In Stock £50.26
