BenQ GL2580HM 25" 1920x1080 5ms DVI-D HDMI LED Monitor with Speakers
Quicklinx: D0LTWS00 Mfr#: 9H.LGGLB.QBU
Diagonal Size: 24.5in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
More than 50 in stock
£151.49 ex VAT
£181.78 inc VAT
BenQ GL2580HM 24.5" frameless monitor combines ultra slim bezels with hidden cable management. BenQ exclusive Eye-Care™ Technology with Low Blue Light and Flicker-Free performance delivers exquisite details in any environment.
  • Streamlined productivity & simplified lifestyle
    Designed for beautiful simplicity, BenQ GL2580HM frameless monitor combines ultra slim bezels with hidden cable management. BenQ exclusive Eye-Care technology with Low Blue Light and Flicker-Free performance delivers exquisite details in any environment. Combining LED and fast-response TN technologies, GL2580HM delivers an amazing level of visual enjoyment with truly authentic colors, deeper blacks, higher contrast, and sharper details.
  • Ultra slim bezel design
    GL2580HM offers a visually spectacular edge-to-edge panel with ultra slim bezels and elegant profile that beautifully complements any modern decor.
  • Cable management system
    Invisible cable management system neatly hides all wires inside the monitor stand for a clean look.
  • Fast response time
    Super-fast response eliminates motion smear for smooth video and gaming. Fast-moving action and dramatic transitions render flawlessly without lag or ghosting. Enjoy immersive gaming and video entertainment without delay.
  • Low Blue Light
    Proprietary BenQ Low Blue Light technology filters out hazardous blue light, effectively reducing eye fatigue and irritation.
  • Flicker-Free technology
    Exclusive BenQ Flicker-Free technology eliminates the harmful flicker of traditional LCDs to prevent fatigue and vision damage.
BenQ GL2580HM - LED monitor - Full HD (1080p) - 24.5"
LED-backlit LCD monitor - 24.5"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
55.749 cm x 17.511 cm x 42.633 cm
4.4 kg
Environmental Standards
TCO Certified ENERGY STAR Qualified
Display Type
Energy Class
Class A
32 kWh
22 W
Diagonal Size
24.5"
Viewable Size
24.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
OSD Languages
Hungarian, Czech, Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Arabic, Romanian, Japanese, Chinese, Korean
HDCP, 72% colour gamut, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Flicker Free technology, Low Blue Light Plus technology
55.749 cm x 17.511 cm x 42.633 cm - with stand
4.4 kg
Audio
Speakers
Output Power / Channel
1 Watt
Headphones , HDMI , DVI , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.5 m
Security Slot Type
Kensington security slot
AC 100 - 240 V
17 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 55.749 cm - depth: 17.511 cm - height: 42.633 cm - weight: 4.4 kg
ENERGY STAR Certified
BenQ GL2580HM 25 Bundle deal on BenQ GL2580HM 25" 1920x1080 5ms DVI-D HDMI LED Monitor with Speakers
£250.66
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: BenQ
Price Range Ex VAT: 150 - 300
