Product
BenQ GL2580H 25" 1920x1080 5ms DVI-D HDMI LED Monitor
Quicklinx: D0LPWS00 Mfr#: 9H.LGFLB.QBU
Diagonal Size: 24.5in
Max Resolution: 1920 x 1080
Response Time: 1ms
Interfaces: DVI, HDMI, VGA (HD-15)
42 in stock
£139.82 ex VAT
£167.78 inc VAT
BenQ GL2580H 24.5" frameless monitor combines ultra slim bezels with hidden cable management. BenQ exclusive Eye-Care™ Technology with Low Blue Light and Flicker-Free performance delivers exquisite details in any environment.
  • Streamlined productivity & simplified lifestyle
    Designed for beautiful simplicity, BenQ GL2580H frameless monitor combines ultra slim bezels with hidden cable management. BenQ exclusive Eye-Care technology with Low Blue Light and Flicker-Free performance delivers exquisite details in any environment. Combining LED and fast-response TN technologies, GL2580H delivers an amazing level of visual enjoyment with truly authentic colors, deeper blacks, higher contrast, and sharper details.
  • Ultra slim bezel design
    GL2580H offers a visually spectacular edge-to-edge panel with ultra slim bezels and elegant profile that beautifully complements any modern decor.
  • Cable management system
    Invisible cable management system neatly hides all wires inside the monitor stand for a clean look.
  • Fast response time
    Super-fast response eliminates motion smear for smooth video and gaming. Fast-moving action and dramatic transitions render flawlessly without lag or ghosting. Enjoy immersive gaming and video entertainment without delay.
  • Low Blue Light
    Proprietary BenQ Low Blue Light technology filters out hazardous blue light, effectively reducing eye fatigue and irritation.
  • Flicker-Free technology
    Exclusive BenQ Flicker-Free technology eliminates the harmful flicker of traditional LCDs to prevent fatigue and vision damage.
BenQ GL2580H - LED monitor - Full HD (1080p) - 24.5"
LED-backlit LCD monitor - 24.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
55.749 cm x 17.511 cm x 42.633 cm
4.4 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 7.0
Display Type
Diagonal Size
24.5"
Viewable Size
24.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
72% colour gamut, 8-bit gamma
55.749 cm x 17.511 cm x 42.633 cm - with stand
4.4 kg
Headphones , HDMI , DVI , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
TCO Displays 7.0
Security Slot Type
Kensington security slot
AC 100 - 240 V
16.5 Watt
ENERGY STAR Certified
BenQ GL2580H 25 Bundle deal on BenQ GL2580H 25" 1920x1080 5ms DVI-D HDMI LED Monitor
£234.83
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: BenQ
Price Range Ex VAT: 100 - 150
