BenQ GL2460HM 24" 1920x1080 5ms DVI-D HDMI Speakers LED Monitor
Quicklinx: 9G6ZWS00 Mfr#: 9H.LA7LB.QBE
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2460HM LED monitor is the perfect choice for you in style! Featuring Senseye Human Vision technology with optimized eco mode and reading mode, a dynamic ratio of 12M:1, and 2 ms GtG response time, this 24" 16:9 LED monitor delivers every image detail with the best viewing quality. And, its HDMI connectivity leads the path to a whole level of multimedia enjoyment.
  • Brilliant image quality - LED leads the way
    LED backlighting offers significant advantages over the CCFL technology used in older LCD monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants.
  • An integral part of your home and workplace decor
    GL60 series blends perfectly with any decor, adding a hint of low-key elegance to your living space with its high-gloss frame and base stand streamlined by a curvaceous neck that creates stunning visual fluidity. Beautiful from any angle, the back of the GL2460HM is carbon fiber patterned to recreate the powerful drive of a racing car and energize their whole appearance. Incorporating a 16 mm slim bezel display, GL60 series creates a sophisticated look while keeping things nice and compact. You'll find multi-panel configuration for home entertainment or office viewing use much simpler with less distraction from the monitor frame.
  • Reading mode for an optimized reading experience
    For a more comfortable reading experience, BenQ has adjusted the monitor's color temperature, brightness, contrast ratio and sharpness to create the all Reading Mode which simulates the look of printed paper to help reduce the eye discomfort typically caused by prolonged and focused use of eyes on computer monitors.
  • Improved eco mode for higher energy efficiency
    The improved eco mode adjusts the backlight brightness level to ensure the highest display quality is presented to you with the highest energy efficiency. This intelligent mode reduces at least 37% of the power consumed by document viewing, Internet browsing and emailing and up to 44% of the power consumed by gaming.
  • 12M: 1 dynamic contrast ratio for color depth and definition
    The GL2460HM comes with a dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
  • Perfecting your audiovisual enjoyment with speakers
    Whether you're listening to music or watching your favorite film, simply turn on the speakers to experience the audiovisual fun!
  • HDMI multimedia interface
    The latest HDMI high-speed multimedia interface makes these monitors incredibly convenient to use -V now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future.
  • Full HD 1080p 16:9 visual perfection
    The BenQ GL2460HM supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing.
  • Superior response time
    Enjoy high dynamic videos without ghosting or other artifacts with 2 ms GtG response time.
  • ENERGY STAR qualified
    The GL2460HM complies with the requirement of ENERGY STAR program for computer monitors. Now you can enjoy saving energy and money as well as keeping the Earth lookin' great!
BenQ GL2460HM - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Glossy black
56.5 cm x 19.4 cm x 43.4 cm
4.3 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms (gray-to-gray)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Eco-Mode, Advanced Motion Accelerator (AMA) technology, Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
56.5 cm x 19.4 cm x 43.4 cm - with stand
4.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI (HDCP) , HDMI
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Power Supply
Internal
AC 120/230 V
23 Watt
Power Consumption Stand by / Sleep
0.3 Watt
0.3 Watt
On / Off Switch
No
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
