Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2460HM LED monitor is the perfect choice for you in style! Featuring Senseye Human Vision technology with optimized eco mode and reading mode, a dynamic ratio of 12M:1, and 2 ms GtG response time, this 24" 16:9 LED monitor delivers every image detail with the best viewing quality. And, its HDMI connectivity leads the path to a whole level of multimedia enjoyment.
Brilliant image quality - LED leads the way
LED backlighting offers significant advantages over the CCFL technology used in older LCD monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants. -
An integral part of your home and workplace decor
GL60 series blends perfectly with any decor, adding a hint of low-key elegance to your living space with its high-gloss frame and base stand streamlined by a curvaceous neck that creates stunning visual fluidity. Beautiful from any angle, the back of the GL2460HM is carbon fiber patterned to recreate the powerful drive of a racing car and energize their whole appearance. Incorporating a 16 mm slim bezel display, GL60 series creates a sophisticated look while keeping things nice and compact. You'll find multi-panel configuration for home entertainment or office viewing use much simpler with less distraction from the monitor frame. -
Reading mode for an optimized reading experience
For a more comfortable reading experience, BenQ has adjusted the monitor's color temperature, brightness, contrast ratio and sharpness to create the all Reading Mode which simulates the look of printed paper to help reduce the eye discomfort typically caused by prolonged and focused use of eyes on computer monitors. -
Improved eco mode for higher energy efficiency
The improved eco mode adjusts the backlight brightness level to ensure the highest display quality is presented to you with the highest energy efficiency. This intelligent mode reduces at least 37% of the power consumed by document viewing, Internet browsing and emailing and up to 44% of the power consumed by gaming. -
12M: 1 dynamic contrast ratio for color depth and definition
The GL2460HM comes with a dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. -
Perfecting your audiovisual enjoyment with speakers
Whether you're listening to music or watching your favorite film, simply turn on the speakers to experience the audiovisual fun! -
HDMI multimedia interface
The latest HDMI high-speed multimedia interface makes these monitors incredibly convenient to use -V now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future. -
Full HD 1080p 16:9 visual perfection
The BenQ GL2460HM supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing. -
Superior response time
Enjoy high dynamic videos without ghosting or other artifacts with 2 ms GtG response time. -
ENERGY STAR qualified
The GL2460HM complies with the requirement of ENERGY STAR program for computer monitors. Now you can enjoy saving energy and money as well as keeping the Earth lookin' great!
- BenQ GL2460HM - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 39 kWh
- Power Consumption (On mode)
- 27 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 2 ms (gray-to-gray)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V
- Glossy black
- 56.536 cm x 19.382 cm x 43.345 cm
- 4.3 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- HDCP 1.4
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 39 kWh
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Pixel Per Inch
- 92
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Romanian, Japanese, Serbo-Croatian
- HDCP, Advanced Motion Accelerator (AMA) technology, Flicker Free technology, K Locker, Eye-Care Technology, Low Blue Light technology, 72% NTSC colour gamut
- Glossy black
- 56.536 cm x 19.382 cm x 43.345 cm - with stand
- 4.3 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI-D (HDCP) , HDMI , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand, plate
- Cables Included
- 1 x VGA cable
- HDCP 1.4
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 27 W
- Power Consumption (Typical)
- 35 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 56.536 cm - depth: 19.382 cm - height: 43.345 cm - weight: 4.3 kg , With wall mount - width: 56.536 cm - depth: 5.4 cm - height: 33.3 cm
- Shipping Width
- 64.9 cm
- Shipping Depth
- 12.3 cm
- Shipping Height
- 41.7 cm
- Shipping Weight
- 5.8 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Limited warranty - 3 years
