BenQ GL2450HT 24" 1920x1080 5ms DVI-D HDMI LED Monitor
Quicklinx: BZ8PWS00 Mfr#: 9H.L7CLA.4BE
Build with an LED backlight panel, 16:9 100% dot-to-dot image quality, high adjustment stand and BenQ's exclusive Senseye technology to offer you the best viewing quality at all times. With the GL2450HT LED monitor, things are certainly looking great!
  • Sophisticated harmony with layering design
    GL2450HT is not only bringing great visual performance to your workstation and house, but also a harmony of a variety of visual elements. The breakthrough layering design comes with a clearly sculptured countenance, as well as crispy shaped oval base stand which effectively reduce impressions of bulkiness.
  • Height Adjustment Stand (HAS)
    The HAS allows you to find the best viewing angles for personal work or screen sharing with an extensive range of monitor adjustments - height, tilt, pivot, stroke and swivel. The screen bottom can be 110 mm from the base now.
  • 12M:1 ultra high dynamic contrast for depth and definition
    The GL2450HT comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
  • BenQ LED monitors conventional LCD Monitors Senseye technology
    Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eco - with the eco mode especially designed to save power and money.
  • Perfecting your audiovisual enjoyment with speakers
    Whether you're listening to music or watching your favorite film, simply turn on the speakers (2 W x 2) to experience the audiovisual fun!
BenQ GL2450HT - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms (gray-to-gray), 5 ms (tr - tf)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Voltage
AC 120/230 V
Glossy black
57.9 cm x 21.3 cm x 50.2 cm
5.1 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
39 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Advanced Motion Accelerator (AMA) technology, Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
57.9 cm x 21.3 cm x 50.2 cm - with stand
5.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D (HDCP) , HDMI , VGA , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+15
Swivel Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
AC 120/230 V
27 W
Power Consumption (Typical)
23 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
Sustainability Information
ENERGY STAR Certified
BZ8P C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
