BenQ GL2450HT 24" 1920x1080 5ms DVI-D HDMI LED Monitor
Quicklinx: BZ8PWS00 Mfr#: 9H.L7CLA.4BE
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 2ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
More than 50 in stock
£145.93 ex VAT
£175.11 inc VAT
Build with an LED backlight panel, 16:9 100% dot-to-dot image quality, high adjustment stand and BenQ's exclusive Senseye technology to offer you the best viewing quality at all times. With the GL2450HT LED monitor, things are certainly looking great!
  • Sophisticated harmony with layering design
    GL2450HT is not only bringing great visual performance to your workstation and house, but also a harmony of a variety of visual elements. The breakthrough layering design comes with a clearly sculptured countenance, as well as crispy shaped oval base stand which effectively reduce impressions of bulkiness.
  • Height Adjustment Stand (HAS)
    The HAS allows you to find the best viewing angles for personal work or screen sharing with an extensive range of monitor adjustments - height, tilt, pivot, stroke and swivel. The screen bottom can be 110 mm from the base now.
  • 12M:1 ultra high dynamic contrast for depth and definition
    The GL2450HT comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
  • BenQ LED monitors conventional LCD Monitors Senseye technology
    Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eco - with the eco mode especially designed to save power and money.
  • Perfecting your audiovisual enjoyment with speakers
    Whether you're listening to music or watching your favorite film, simply turn on the speakers (2 W x 2) to experience the audiovisual fun!
BenQ GL2450HT - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (tr - tf); 2 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Glossy black
57.9 cm x 21.3 cm x 50.2 cm
5.1 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 5.2
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, 72% colour gamut, Advanced Motion Accelerator (AMA) technology, Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
57.9 cm x 21.3 cm x 50.2 cm - with stand
5.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D (HDCP) , HDMI , VGA , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+15
Swivel Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
TCO Displays 5.2
Security Slot Type
Kensington security slot
Power Supply
Internal
AC 120/230 V
23 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
ENERGY STAR Certified
BenQ GL2450HT 24 Bundle deal on BenQ GL2450HT 24" 1920x1080 5ms DVI-D HDMI LED Monitor
£245.69
BZ8P C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.20
BZ8P C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.58
BZ8P C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £17.40
BZ8P C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
BZ8P C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £40.16
BZ8P C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.91
Diagonal Size: 24in
Response Time: 2ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: BenQ
Price Range Ex VAT: 100 - 150
