BenQ GL2450HM 24" 1920x1080 5ms DVI HDMI VGA LED Monitor
Quicklinx: BSXQWS00 Mfr#: 9H.LDMLA.TBE
Select:
  • 23.8"
The GW2470H VA LED monitor brings viewing pleasure to everyday work and play with exquisite details on the exterior and striking visual performance delivered by 3000:1 high contrast ratio, 178°/178°wide-viewing angle, dual HDMI and BenQ's eye-caring design, which consists of BenQ's flicker-free technology and low blue light modes.
  • Everyday enjoyment for leisure and business
    A perfect embodiment of the Bauhaus' "less is more" minimalism design philosophy, the GW2470H is a delightful complement to almost any modern space. Every aspect of its form and feature is reduced to unify simplicity and functionality into pure aesthetics. On top of it all, users get to enjoy the sheerest visual pleasure and optimal eye comfort with BenQ's exclusive eye-caring technology. The GW2470H is not only a celebration of minimalist lifestyle and modern sleekness but also the gateway to everyday enjoyment for leisure and business.
  • Designed simply for the ultimate sophistication
    Exquisitely refined to complement your home and office, every detail of the GW2740H exemplifies the highest craftsmanship. The T-shaped base surface in the front is brushed with hairline treatment and adorned by a rectangular-shaped glossy black embellishment. The housing styled in black is fashioned with delicate patterns in the back to subtly catch the eye.
  • Flicker-free backlight for visual pleasure
    The flicker-free technology eliminates flickering at all brightness levels and reduces eye fatigue effectively. Conventional LCD screens flicker at the rate of 200 times per second. Your eyes may not see the flickers but they can certainly feel them. So relieve your eyes from the uncomfortable flickering effect by switching to a BenQ flicker-free monitor.
  • Better eye protection with low blue light modes
    Every monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping discorders. BenQ's unique low blue light technology is designed to deal with the everyday problem of blue light exposure and allows healthier time spent in front of your computer.
  • 3000:1 native contrast ratio for color depth and definition
    An ultra-high native contrast of 3000:1, which is three times of that of general panels, adds astonishing color depth and definition to darkened, complex images with the greatest subtlety and clarity. With a native contrast ratio this high, you can expect an infinite dynamic contrast ratio that far exceeds your expectations.
  • True 8-bit color performance
    An 8-bit VA panel delivers smoother and more stable color transitions by rendering a total of 16.7 million color shades simultaneously. A 6-bit panel with Advanced Frame Rate Control (AFRC) requires interpolation to display the same number of colors as a true 8-bit panel does.
  • 178°/178° wide-viewing angles
    VA panels bring truly authentic colors and ultra sharp details from left, right, above and below to your eyes with a wide-viewing angle of 178°/178°. Viewing, as you know it, will never be the same.
  • HDMI multimedia interface
    The HDMI high-speed multimedia interface makes these monitors incredibly convenient to use - now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future.
BenQ GW2470H - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey), 16 ms (tr - tf)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
2xHDMI, VGA
Voltage
AC 120/230 V
Black texture, glossy black
55.3 cm x 18.9 cm x 42.5 cm
4 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class B
39 kWh
Diagonal Size
23.8"
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Low Blue Light Mode, 8-bit gamma, 72% NTSC colour gamut
55.3 cm x 18.9 cm x 42.5 cm - with stand
4 kg
VGA , 2 x HDMI , Headphones
Mechanical
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Flicker-free technology
Stand
1 x HDMI cable , 1 x VGA cable
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
27 W
Power Consumption (Typical)
23 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 55.3 cm - depth: 18.9 cm - height: 42.5 cm - weight: 4 kg , Without stand - width: 55.3 cm - depth: 5.1 cm - height: 32.9 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
Accessories (4)
BSXQ StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
BSXQ StarTech.com Articulating Monitor Arm In Stock £132.69
BSXQ StarTech.com Dual Monitor Stand In Stock £91.00
BSXQ StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
Other bundles (1)
BSXQ C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
