BenQ GL2450 - LED monitor - 24" - Senseye Human Vision tech
Quicklinx: 922LWS00 Mfr#: 9H.L7ALA.
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2450 LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12M:1, Senseye Human Vision technology, 5ms response time and DVI connector, this 24" W 16:9 LED monitor delivers every image detail with the best viewing quality.
  • LED leads the way
    LED backlighting offers significant advantages over the CCFL technology used in older LCD monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants.
  • 12M:1 ultra high dynamic contrast for depth and definition
    The GL2450 comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
  • Full HD 1080p 16:9 visual perfection
    The BenQ GL2450 supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing.
  • Superior response time
    Enjoy high dynamic videos without ghosting or other artifacts with 5ms response time.
  • Senseye technology
    Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eco - with the Eco Mode especially designed to save power and money.
  • Save energy to save up
    Energy-efficient LED panel provides greater power saving by 14.3% and with the help of eco mode, you can save up to 39.3%.
  • Win 7 compatible
    The GL2450 has passed Windows 7 certification and are fully compatible with Windows 7 color systems. Plug in the GL2450 to your computer, and Windows 7 will recognize it instantly, making setup and connection effortless.
  • ecoFACTS label
    ecoFACTS can tell you how eco-friendly BenQ products are!
  • Energy Star qualified
    The GL2450 complies with the requirement of ENERGY STAR program for computer monitors, Version 5.0. Now you can enjoy saving energy and money as well as keeping the Earth looking great!
BenQ GL2450 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
Glossy black
57.939 cm x 17.912 cm x 35.098 cm
4.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Display Type
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
4.1 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
AC 120/230 V
Power Consumption (Typical)
34 Watt
Sustainability Information
ENERGY STAR Certified
