BenQ GL2250HM 21.5" 1920x1080 2ms DVI HDMI LED Monitor
Quicklinx: 9G0FWS00 Mfr#: GL2250HM
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2250HM LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12M:1, speakers, response time of 2ms and DVI and HDMI connector, this 21.5"W 16:9 LED monitor delivers you the audiovisual enjoyment.
  • LED leads the way
    LED backlighting offers significant advantages over the CCFL technology used in older LCD monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants.
  • 12M:1 ultra high dynamic contrast for depth and definition
    The GL2250HM comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
  • Perfecting your audiovisual enjoyment with speakers
    Whether you're listening to music or watching your favorite film, simply turn on the speakers to experience the audiovisual fun!
  • HDMI multimedia interface
    The latest HDMI high-speed multimedia interface makes these monitors incredibly convenient to use - now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future.
  • Superior response time
    Enjoy high dynamic videos without ghosting or other artifacts with 2ms GTG response time.
  • Senseye 3 visual solution to your everyday viewing needs
    Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eco - with the eco mode especially designed to save power and money.
  • Save energy to save up
    Energy-efficient panel provides greater power saving by 14.3% when speakers are on, in comparison with G2222HD.
  • Win 7 compatible
    The GL2250HM has passed Windows 7 certification and are fully compatible with Windows 7 color systems. Plug in the GL2250HM to your computer, and Windows 7 will recognize it instantly, making setup and connection effortless.
  • ecoFACTS label
    ecoFACTS can tell you how eco-friendly BenQ products are!
  • Energy Star qualified
    The GL2250HM complies with the requirement of Energy Star program for computer monitors, version 5.1. Now you can enjoy saving energy and money as well as keeping the Earth looking great!
BenQ GL2250HM - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
25 W
Stereo speakers
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms (gray-to-gray), 5 ms (typical)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
52.3 cm x 17.4 cm x 40 cm
3.8 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
36 kWh
Diagonal Size
21.5"
Built-in Devices
Stereo speakers
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Senseye Human Vision Technology, Senseye 3 Technology
3.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
25 W
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
Sustainability Information
ENERGY STAR Certified
