Your basket is empty
BenQ GL2250HM 21.5" 1920x1080 2ms DVI HDMI LED Monitor
Quicklinx: 9G0FWS00 Mfr#: GL2250HM
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2250HM LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12M:1, speakers, response time of 2ms and DVI and HDMI connector, this 21.5"W 16:9 LED monitor delivers you the audiovisual enjoyment.
BenQ GL2250HM - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
25 W
Stereo speakers
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (typical); 2 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
52.3 cm x 17.4 cm x 40 cm
3.8 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 5.0
Display Type
Energy Class
Class B
36 kWh
25 W
Diagonal Size
21.5"
Built-in Devices
Stereo speakers
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Senseye Human Vision Technology, Senseye 3 Technology
3.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
Wall mountable, K-lock security slot
1 x VGA cable
TCO Displays 5.0
Power Supply
Internal
30 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
ENERGY STAR Certified
