BenQ GL2023A 19.5" 1600x900 5ms VGA Black Monitor
Quicklinx: 8NVQWS00 Mfr#: 9H.LA1LB.Q8E
Whether you're catching up on the show on the Internet or viewing documents, the BenQ GL2023A LED monitor is the perfect choice for you! Featuring a dynamic contrast ratio of 12M: 1, response time of 5 ms, and BenQ's exclusive Senseye technology, this 19.5"W 16:9 LED monitor delivers you the visual enjoyment with best value.
  • Brilliant image quality LED leads the way
    LED backlighting offers significant advantages over the CCFL technology used in older LED monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants.
  • 12M: 1 ultra high dynamic contrast for depth and definition
    The GL2023A comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
  • Superior response time
    Enjoy high dynamic videos without ghosting or other artifacts with 5 ms response time.
  • Senseye technology
    Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes -VStandard, movie, game, photo, sRGB, and Eco -V with the Eco Mode especially designed to save power and money.
  • ENERGY STAR qualified
    The GL2023A complies with the requirement of ENERGY STAR Program for computer monitors. Now you can enjoy saving energy and money as well as keeping the Earth lookin' great!
BenQ GL2023A - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
Glossy black
47.7 cm x 16.5 cm x 35.9 cm
2.9 kg
Display Type
Diagonal Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
47.7 cm x 16.5 cm x 35.9 cm - with stand
2.9 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
AC 120/230 V
Power Consumption (Typical)
15 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Microsoft Windows 7, Windows 8
