Your basket is empty
BenQ GL2023A 19.5" 1600x900 5ms VGA Black Monitor
Quicklinx: C94GWS00 Mfr#: 9H.LA1LA.D8E
Diagonal Size: 19.5in
Max Resolution: 1600 x 900
Response Time: 5ms
Interfaces: VGA (HD-15)
Select:
32 in stock
£57.42 ex VAT
£68.90 inc VAT
Express delivery Order within the next 18 hours for delivery on Tuesday
Whether you're catching up on the show on the Internet or viewing documents, the BenQ GL2023A LED monitor is the perfect choice for you! Featuring a dynamic contrast ratio of 12M: 1, response time of 5 ms, and BenQ's exclusive Senseye technology, this 19.5"W 16:9 LED monitor delivers you the visual enjoyment with best value.
BenQ GL2023A - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Glossy black
47.7 cm x 16.5 cm x 35.9 cm
2.9 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
Display Type
Diagonal Size
19.5"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
72% colour gamut, Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
47.7 cm x 16.5 cm x 35.9 cm - with stand
2.9 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
Stand
TCO Displays 6.0
Power Supply
Internal
AC 120/230 V
15 Watt
Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 47.7 cm - depth: 16.5 cm - height: 35.9 cm - weight: 2.9 kg , Without stand - width: 47.7 cm - depth: 7.8 cm - height: 35.2 cm
C94G C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE In Stock £7.60
C94G C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable In Stock £8.01
C94G C2G 2m Premium HD15 Male to RGBHV (5-BNC) Male Video Cable In Stock £10.01
C94G C2G VGA to Composite PC-TV Video Adapter In Stock £34.13
Response Time: 5ms
Brand: BenQ
Price Range Ex VAT: 50 - 100
