Infused with exquisite simplicity, the GC2870HE is a perfect embodiment of the "less is more" minimalistic way of modern living. A treat for the eye, wide color gamut display is designed and built with high-performance features, dual HDMI connectivity for exceptional image details and colors and BenQ's eye-caring technology. This is all to give you the best viewing experience for work and play.
Wide color gamut
The GC2870HE's wide color gamut accentuates colors for true-to-life images. This monitor's 85% NTSC color gamut coverage well exceeds conventional 72% NTSC coverage rate for better color reproduction, particularly in the red, green, yellow, and magenta color spectrums. The expanded gamut produces more vivid pictures for all consumer and business applications, whether daily web-surfing, stimulating and immersive gaming, colorful photo viewing, or captivating video playback. -
Low blue light mode
Every monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. Switch to one of the four preset Low Blue Light Modes from OSD hot key (Multimedia - 30% reduction, Web-surfing - 50% reduction, Office - 60% reduction, Reading - 70% reduction), and reward your eyes without having to lose the visual enjoyment. -
Flicker-free backlight for visual pleasure
The GC2870HE is upgraded to eliminate flickering at all brightness levels, effectively reducing eye fatigue. -
178°/178° wide-viewing angles
VA panels come with an ultra-wide viewing angle of 178°/178° from left, right, above and below. With sharper details, higher contrast and truly authentic colors; viewing, as you know it, has just gotten easier! -
True 8-bit color performance
A true 8-bit VA panel delivers smoother and more stable color transitions by rendering a total of 16.7 million color shades simultaneously. In contrast, a 6-bit panel with Advance Frame Rate Control (AFRC) requires extra interpolation to simulate the same number of colors as a true 8-bit panel does.
- BenQ GC2870HE - LED monitor - Full HD (1080p) - 28"
- LED-backlit LCD monitor - 28"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.32 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey), 20 ms (typical)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 85% NTSC
- Input Connectors
- 2xHDMI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Black texture, glossy black
- Dimensions (WxDxH) - without stand
- 65.9 cm x 5.4 cm x 38.1 cm
- 5.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Diagonal Size
- 28"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.32 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 85% NTSC
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, Colour Temperature Selection
- 65.9 cm x 5.4 cm x 38.1 cm - without stand
- 5.5 kg
- 2 x HDMI , VGA , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- VGA cable , HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 30 Watt
- OS Required
- Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
- Dimensions & Weight Details
- With stand - width: 65.9 cm - depth: 20.4 cm - height: 47.7 cm , Without stand - width: 65.9 cm - depth: 5.4 cm - height: 38.1 cm
Sustainability Information
- ENERGY STAR Certified
