BenQ GC2870H 28" 1920x1080 5ms HDMI LED Monitor
Quicklinx: CNRPWS00 Mfr#: 9H.LEKLA.TBE
Diagonal Size: 28in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: HDMI
£151.49 ex VAT
£181.78 inc VAT
The GC2870H VA LED monitor brings viewing pleasure to everyday work and play with exquisite details on the exterior and striking visual performance delivered by wide color gamut, true 8-bit color, 3000:1 high contrast ratio, 178°wide-viewing angle, dual HDMI and BenQ's eye-caring design, which consists of BenQ‘s Flicker-free technology and low blue light modes.
  • Everyday enjoyment for leisure and business
    A perfect embodiment of The Bauhaus' "less is more" minimalism design philosophy, the GC2870H is a delightful complement to almost any modern space. Every aspect of its form and feature is reduced to unify simplicity and functionality into pure aesthetics. On top of it all, users get to enjoy the sheerest visual pleasure and optimal eye comfort with BenQ's exclusive eye-caring technology. The GC2870H is not only a celebration of minimalist lifestyle and modern sleekness but also the gateway to everyday enjoyment for leisure and business.
  • Designed simply for the ultimate sophistication
    Exquisitely refined to complement your home and office, every detail of the GC2870H exemplifies the highest craftsmanship. The T-shaped base surface in the front is brushed with hairline treatment and adorned by a rectangular-shaped glossy black embellishment. The housing is fashioned with delicate patterns in the back to subtly catch the eye. With this classic minimalistic wonder, the GC2870H is everything you seek for the ultimate sophistication.
  • Wide color gamut
    The GC2870H's wide color gamut accentuates colors for true-to-life images. This monitor's 85% NTSC color gamut coverage well exceeds conventional 72% NTSC coverage rate for better color reproduction, particularly in the red, green, yellow, and magenta color spectrums. The expanded gamut produces more vivid pictures for all consumer and business applications, whether daily web-surfing, stimulating and immersive gaming, colorful photo viewing, or captivating video playback.
  • Flicker-free backlight for visual pleasure
    The Flicker-free technology eliminates flickering at all brightness levels and reduces eye fatigue effectively. Conventional LCD screens flicker at the rate of 200 times per second. Your eyes may not see the flickers but they can certainly feel them. So relieve your eyes from the uncomfortable flickering effect by switching to a BenQ Flicker-free monitor.
  • With Low Blue Light modes
    Every monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping discorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows healthier time spent in front of your computer. Switch to one of the four preset blue light modes and reward yours eyes without having to lose the visual enjoyment.
  • 3000:1 native contrast ratio for color depth and definition
    An ultra-high native contrast of 3000:1, which is three times of that of general panels, adds astonishing color depth and definition to darkened, complex images with the greatest subtlety and clarity. With a native contrast ratio this high, you can expect an infinite dynamic contrast ratio that far exceeds your expectations.
  • True 8-bit color performance
    An 8-bit VA panel delivers smoother and more stable color transitions by rendering a total of 16.7 million color shades simultaneously. A 6-bit panel with Advanced Frame Rate Control (AFRC) requires interpolation to display the same number of colors as a true 8-bit panel does.
  • HDMI multimedia interface
    The latest HDMI high-speed multimedia interface makes these monitors incredibly convenient to use - now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future.
BenQ GC2870H - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
57 kWh
Power Consumption (On mode)
39 W
Panel Type
VA
Aspect Ratio
16:9
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Glossy black
65.89 cm x 5.415 cm x 38.13 cm
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
57 kWh
39 W
Diagonal Size
28"
Panel Type
VA
Aspect Ratio
16:9
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Eco-Mode, Senseye Technology, Dynamic Power Saving (DPS), Flicker Free technology, 85% NTSC (CIE 1976) colour gamut
Glossy black
65.89 cm x 5.415 cm x 38.13 cm - without stand
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
1 x VGA cable - 1.5 m , 1 x HDMI cable - 1.5 m
Security Slot Type
Kensington security slot
AC 120/230 V
38 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 65.89 cm - depth: 20.367 cm - height: 47.68 cm , Without stand - width: 65.89 cm - depth: 5.415 cm - height: 38.13 cm
ENERGY STAR Certified
BenQ GC2870H 28 Bundle deal on BenQ GC2870H 28" 1920x1080 5ms HDMI LED Monitor
£250.66
Diagonal Size: 28in
Response Time: 5ms
Interfaces: HDMI
Brand: BenQ
Price Range Ex VAT: 150 - 300
