BenQ EW3270ZL 32" 2560x1440 4ms HDMI LED Monitor
Quicklinx: CNRRWS00 Mfr#: 9H.LFRLB.QBE
Diagonal Size: 32in
Max Resolution: 2560 x 1440
Response Time: 12ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£350.26 ex VAT
£420.31 inc VAT
Featuring an AMVA+ panel, the 32 inch LED monitor incorporates Brightness Intelligence technology to optimize the display performance for multimedia enjoyment. Experience visual comfort during extended viewing with BenQ's Eye-care technology which includes Low Blue Light Plus mode and Flicker-free technology. Slim bezel design beautifully complements any space.
  • Brightness Intelligence technology
    Brightness Intelligence technology optimizes display performance for movie watching, protecting your eyes while delivering premium image quality.
  • Picture perfect content
    Brightness Intelligence technology detects the intensity of your content and adjusts to ensure that bright scenes don't get overexposed while dark areas automatically adjust to maintain a visible level of clarity.
  • Reduce eye strain in any lighting environment
    Brightness Intelligence technology can detect the amount of ambient light in your viewing environment and make automatic adjustments to brightness for the most comfortable viewing experience possible.
  • 32" large monitor
    Enjoy the larger area, 41% over screen space than 27" to find more and precise details.
  • Optimal color precision
    With 10-bits of color depth, Rec.709 and 100% sRGB color space, you'll have more than 1 billion of colors to work with astonishing precision.
  • Super resolution
    To give you an optimal movie watching experience, Super Resolution simulates high-resolution images by boosting the pixel density of the original video source.
  • Smart Focus
    Smart Focus allows you to pinpoint an area on the screen and make that the focal point. The highlighted area remains bright while the surrounding area is dimmed so you're able to focus on what you enjoy.
  • Multi-device connectivity
    Enjoy greater flexibility and the best possible video image quality from external sources with HDMI, DisplayPort, and Mini DisplayPort inputs for multi-device connection.
  • Low Blue Light Plus technology
    Low Blue Light Plus technology filters out the shorter, higher energy blue-violet radiation (420~455nm) which is harmful to the eyes while the remaining beneficial blue turquoise light (455~480nm) remains.
  • Flicker-free
    Flicker-free technology eliminates on-screen flickering at all brightness levels to reduce eye fatigue. Because the monitor has a constant steady light source, it is ideal for those looking for improved visual comfort.
  • AMVA+ panel
    EW3270ZL utilizes an AMVA+ panel with an ultra-high native contrast ratio of 3000:1, bringing out every hue from the brightest whites to the deepest black with greater subtlety and clarity.
BenQ EW3270ZL - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
73 kWh
Power Consumption (On mode)
50 W
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.276 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Tilt
Textured black
73.958 cm x 21.824 cm x 52.682 cm
8.5 kg
Display Type
Energy Class
Class B
73 kWh
50 W
Diagonal Size
32"
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.276 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Advanced Motion Accelerator (AMA) technology, SUPER Resolution, Dynamic Power Saving (DPS), 100% sRGB colour gamut, Smart Focus, Low Blue Light Mode, Flicker Free technology, K Locker, Low Blue Light Plus technology, Bright Intelligence (B.I.)
Textured black
73.958 cm x 21.824 cm x 52.682 cm - with stand
8.5 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
HDMI , DisplayPort , Mini DisplayPort , Headphones , Audio line-in/out
Mechanical
Tilt
Tilt Angle
-5/+15
Backlight Life
30,000 hours
MTBF
60,000 hour(s)
Security Slot Type
Kensington security slot
AC 90 - 264 V
70 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Microsoft Windows 7 / 8 / 8.1 / 10
Diagonal Size: 32in
Response Time: 12ms
Interfaces: HDMI
Brand: BenQ
Price Range Ex VAT: 300 - 500
