BenQ EW2775ZH 27" 1920x1080 4ms HDMI LED Monitor
Quicklinx: CNRQWS00 Mfr#: 9H.LEELB.QBE
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: HDMI, VGA (HD-15)
42 in stock
£161.10 ex VAT
£193.32 inc VAT
Be easy on your eyes. Enjoy crisp details even in dark scenes with Brightness Intelligence technology. EW2775ZH Eye-care monitor optimizes display performance for videos and movies and automatically adjusting ambient light and on-screen content, protecting your eyes while delivering premium image quality.
  • Better video enjoyment with Brightness Intelligence technology
    Watching your favorite videos and movies should be as easy on your eyes as the content is easy to enjoy. Brightness Intelligence technology optimizes display performance for videos and movies on EW2775ZH by automatically adjusting to ambient light and on-screen content, protecting your eyes while delivering premium image quality. So sit back, relax, and soak up your favorite videos.
  • Picture perfect content
    With Brightness Intelligence technology, you'll enjoy video and images that are balanced and easy on the eyes. The monitor detects the intensity of your content and adjusts to ensure that bright scenes don't get overexposed and dark areas automatically adjust to maintain a visible level of clarity.
  • Reduce eye strain in any lighting environment
    EW2775ZH with Brightness Intelligence technology can detect the amount of ambient light in your viewing environment and make automatic adjustments to brightness for the most comfortable viewing experience possible.
  • Optimizing your viewing experience
    Dive into video with greater definition, color and connectivity.
  • Super resolution
    EW2775ZH can simulate high resolution images by increasing pixel density of video content for added image enhancement.
  • HDMI and I/O port
    Enjoy greater flexibility and the best possible video image quality from external sources with two HDMI and one VGA port.
  • 8-bit display
    With the ability to render 16.7 million color shades simultaneously, you can expect true color performance, silky transitions and impeccable image quality.
  • Caring for your eyes
    BenQ technology protect your eyes while you watch.
  • Low Blue Light Plus technology
    BenQ Low Blue Light Plus technology reduces potentially harmful blue light for safer, healthier monitor use. Low Blue Light Plus technology offers four scenario models for healthy viewing and tailor-made image projection.
  • Flicker-free
    Flicker-free eliminates flickering at all brightness levels to increase eye comfort. The flickering may not be visible to the naked eye, but your eyes must work hard to interpret images on a flickering display.
  • VA panel
    With an ultra-high native contrast ratio of 3000:1, BenQ VA panel portrays every hue and shade with maximum accuracy and subtlety for immersive movie and video experiences that don't strain your eyes.
BenQ EW2775ZH - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
48 kWh
Power Consumption (On mode)
33 W
Stereo speakers
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
12 ms (typical); 4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
61.38 cm x 18.09 cm x 46.06 cm
4.28 kg
Environmental Standards
ENERGY STAR Qualified
TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
Display Type
Energy Class
Class B
48 kWh
33 W
Diagonal Size
27"
Built-in Devices
Stereo speakers
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Senseye Technology, Advanced Motion Accelerator (AMA) technology, 72% NTSC colour gamut, Cinema Mode, Super Resolution Technology, Dynamic Power Saving (DPS), Smart Focus, Low Blue Light Mode, Flicker Free technology, Low Blue Light Plus technology
4.28 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , 2 x HDMI
Mechanical
Tilt
Tilt Angle
-5/+20
1 x HDMI cable - 1.5 m
MTBF
60,000 hour(s)
Security Slot Type
Kensington security slot
42 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
ENERGY STAR Certified
BenQ EW2775ZH 27 Bundle deal on BenQ EW2775ZH 27" 1920x1080 4ms HDMI LED Monitor
£260.27
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: BenQ
Price Range Ex VAT: 150 - 300
