BenQ EW2770QZ 27" 2560x1440 5ms HDMI DisplayPort LED IPS Monitor with Speakers
Quicklinx: D0LYWS00 Mfr#: 9H.LG1LA.TSE
EW2770QZ, the 27 inch 4-sided ultra-slim bezel monitor imbues an aura of exquisite simplicity. Built with 2K QHD resolution and Brightness Intelligence Plus technology.
BenQ EW2770QZ - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
47 kWh
Power Consumption (On mode)
32 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1440p (Quad HD) 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Tilt
Black, silver
61.38 cm x 19.81 cm x 46.06 cm
5.9 kg
Display Type
Energy Class
Class B
47 kWh
32 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 5700K
HDCP, Dynamic Power Saving (DPS), 100% sRGB colour gamut, Smart Focus, Low Blue Light Mode, Flicker Free technology, 100% Rec 709 colour gamut, Bright Intelligence (B.I.)
Black, silver
61.38 cm x 19.81 cm x 46.06 cm - with stand
5.9 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
1 x HDMI cable - 1.5 m
MTBF
60,000 hour(s)
Security Slot Type
Kensington security slot
AC 90 - 264 V
45 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
Apple MacOS, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
Without stand - width: 61.36 cm - depth: 6.43 cm - height: 36.7 cm - weight: 4.46 kg , With stand - width: 61.38 cm - depth: 19.81 cm - height: 46.06 cm - weight: 5.9 kg
