BenQ EW2750ZL, the 27 VA LED monitor offers an edge-to-edge slim bezel design that is ideal for high-quality borderless multimedia enjoyment. Furthermore, it is equipped with BenQ's proprietary Flicker-free technology to eliminate flickering at all brightness levels. This effectively reduces eye fatigue to keep less work on your eyes. It's one of the best eye care monitors choices.
- BenQ EW2750ZL - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Power Consumption (On mode)
- 45 W
- Panel Type
- A-MVA+
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- 2xHDMI, DVI-D
- Voltage
- AC 120/230 V
- Black
- 61.38 cm x 19.49 cm x 45.85 cm
- 4.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Display Type
- Energy Class
- Class B
- Diagonal Size
- 27"
- Panel Type
- A-MVA+
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 4 ms
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- Senseye Technology, Low Blue Light Mode, 72% NTSC colour gamut
- Black
- 4.3 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DVI-D , 2 x HDMI
Mechanical
- Tilt Angle
- -5/+20
- Security lock slot (cable lock sold separately), Flicker-free technology
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 45 W
- Power Consumption Stand by
- 0.5 Watt
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
