BenQ EW2750ZL 27" 1920x1080 4ms HDMI LED Monitor with Speakers
Quicklinx: BSY8WS00 Mfr#: 9H.LDELB.QBE
BenQ EW2750ZL, the 27 VA LED monitor offers an edge-to-edge slim bezel design that is ideal for high-quality borderless multimedia enjoyment. Furthermore, it is equipped with BenQ's proprietary Flicker-free technology to eliminate flickering at all brightness levels. This effectively reduces eye fatigue to keep less work on your eyes. It's one of the best eye care monitors choices.
BenQ EW2750ZL - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Power Consumption (On mode)
45 W
Panel Type
A-MVA+
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
2xHDMI, DVI-D
Voltage
AC 120/230 V
61.38 cm x 19.49 cm x 45.85 cm
4.3 kg
Microsoft Certification
Compatible with Windows 7
Display Type
Energy Class
Class B
Diagonal Size
27"
Panel Type
A-MVA+
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
4 ms
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
Senseye Technology, Low Blue Light Mode, 72% NTSC colour gamut
4.3 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI-D , 2 x HDMI
Mechanical
Tilt Angle
-5/+20
Security lock slot (cable lock sold separately), Flicker-free technology
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
45 W
Power Consumption Stand by
0.5 Watt
BSY8 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
