Your basket is empty
BenQ EW2750ZL 27" 1920x1080 4ms HDMI LED Monitor with Speakers
Quicklinx: BSY8WS00 Mfr#: 9H.LDELB.QBE
BenQ EW2750ZL, the 27 VA LED monitor offers an edge-to-edge slim bezel design that is ideal for high-quality borderless multimedia enjoyment. Furthermore, it is equipped with BenQ's proprietary Flicker-free technology to eliminate flickering at all brightness levels. This effectively reduces eye fatigue to keep less work on your eyes. It's one of the best eye care monitors choices.
BenQ EW2750ZL - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Power Consumption (On mode)
45 W
Panel Type
A-MVA+
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D
61.38 cm x 19.49 cm x 45.85 cm
4.3 kg
Microsoft Certification
Compatible with Windows 7
Display Type
Energy Class
Class B
45 W
Diagonal Size
27"
Panel Type
A-MVA+
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
Senseye Technology, 72% NTSC colour gamut, Low Blue Light Mode
4.3 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI-D , 2 x HDMI
Mechanical
Tilt Angle
-5/+20
K-lock security slot, Flicker-free technology
AC 120/230 V
Power Consumption Stand by
0.5 Watt
BSY8 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BSY8 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
BSY8 C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
BSY8 C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
BSY8 C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
BSY8 C2G Pro HDMI to VGA Converter In Stock £46.35
BSY8 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
