Build with the Flicker-free LED backlight panel, the stylish BL912 comes with an ultra-high dynamic contrast ratio of 120,000:1, and BenQ's exclusive Senseye technology to offer you the best viewing quality at all times.
Designed for office applications make work more efficient
BL912 is not only bringing great visual performance to your workstation and house, but also an essential part of your solutions to minimize total cost of ownership and maximize staff productivity - a win-win decision for the benefits of all. -
Low blue light mode
Every monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. -
Senseye 3 visual solution to your everyday viewing needs
Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eCO - with the eco mode especially design to save power and money. -
12M:1 DCR for depth and definition
The BL912 comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance.
- BenQ BL912 - BL Series - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 41.6 cm x 17.8 cm x 42.45 cm
- 3.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, GS, ISO 9241-307
- 3-year warranty
- Display Type
- Diagonal Size
- 19"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Vertical Refresh Rate
- 76 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, colour temperature
- HDCP, Senseye 3 Technology, Low Blue Light Mode
- Black
- 41.6 cm x 17.8 cm x 42.45 cm - with stand
- 3.5 kg
- DVI-D (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x power cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 17 Watt
- Power Consumption Stand by
- 0.3 Watt
- Dimensions & Weight Details
- Without stand - width: 41.6 cm - depth: 6 cm - height: 37.45 cm , With stand - width: 41.6 cm - depth: 17.8 cm - height: 42.45 cm - weight: 3.5 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - on-site
- 5 °C
- 40 °C
- 20 - 90%
