BenQ BL912 19" 1280x1084 5ms VGA DVI-D Speakers LED Monitor
Quicklinx: 9G6RWS00 Mfr#: 9H.LAPLB.QPE
Select:
  • 19"
Build with the Flicker-free LED backlight panel, the stylish BL912 comes with an ultra-high dynamic contrast ratio of 120,000:1, and BenQ's exclusive Senseye technology to offer you the best viewing quality at all times.
  • Designed for office applications make work more efficient
    BL912 is not only bringing great visual performance to your workstation and house, but also an essential part of your solutions to minimize total cost of ownership and maximize staff productivity - a win-win decision for the benefits of all.
  • Low blue light mode
    Every monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer.
  • Senseye 3 visual solution to your everyday viewing needs
    Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eCO - with the eco mode especially design to save power and money.
  • 12M:1 DCR for depth and definition
    The BL912 comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance.
BenQ BL912 - BL Series - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
41.6 cm x 17.8 cm x 42.45 cm
3.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TUV GS, GS, ISO 9241-307
3-year warranty
Display Type
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, colour temperature
HDCP, Senseye 3 Technology, Low Blue Light Mode
41.6 cm x 17.8 cm x 42.45 cm - with stand
3.5 kg
DVI-D (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x power cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
17 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
Without stand - width: 41.6 cm - depth: 6 cm - height: 37.45 cm , With stand - width: 41.6 cm - depth: 17.8 cm - height: 42.45 cm - weight: 3.5 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - on-site
5 °C
20 - 90%
Accessories (4)
9G6R StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
9G6R StarTech.com Articulating Monitor Arm In Stock £132.69
9G6R StarTech.com Dual Monitor Stand In Stock £91.00
9G6R StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
Other bundles (1)
9G6R C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
