BenQ BL3201PT 32" 3840x2160 4ms DVI HDMI DisplayPort USB IPS LED Monitor
Quicklinx: B221WS00 Mfr#: 9H.LCFLB.QBE
The BL3201PT, a stunning 32"W display built with IPS technology and the latest 4K2K ultra-high-definition resolution, as a part of its continued effort to support the visual-intensive work required in the fields of CAD/CAM, animation, video editing and graphics arts. So professionals with a meticulous eye for detail can work with perfect precision and achieve high productivity.
  • 32" 4K UHD monitor
    Designed to meet the rising demands for large-sized viewing and ultra-high definition, the BL3201PT boasts a 32"W 4K2K display built with BenQ's advanced IPS technology, providing professionals in CAD/CAM, animation, video editing and graphic arts ultra-precise color rendition and over 300% working space to enhance their work efficiency and productivity.
  • 100% sRGB with IPS technology
    Every color is delivered with the finest precision in every detail and at every possible viewing angle for a great viewing experience. With a 10-bit panel that renders more than one billion hues, every image is displayed with the richest, liveliest colors.
  • CAD/CAM
    Professional CAD/CAM engineers and designers work with extremely detailed information, making superb display clarity and color accuracy absolutely vital for ensuring design precision. BenQ's BL series offers a number of display solutions for maximized display performance, including the CAD/CAM Mode to bring out even the smallest details to view for Pro/E, SolidWorks, AutoCad, CATIA or other CAD/CAM software. Recognizing the multi-tasking and collaborative nature of the work, thoughtful features that support a wide range of viewing options are included to ensure high productivity can be preserved while users run a number of tasks simultaneously or compare and discuss design work with colleagues.
  • Animation
    Professional animators work to breath life into moving art, making even the tiniest detail paramount to delivering lively creations. To answer the visual demands of the most sophisticated animators, BenQ BL series monitors give you uncompromising accuracy consistency for displaying every shade of colors through a wide range of optimized image calibration settings, including the brightness-enhancing Animation Mode. There is also a multitude of viewing features incorporated into the monitors to simultaneously display all the information needed for making color adjustments. So no detail can escape the eyes of its creator!
  • Video editing
    Color accuracy and a clear line of view are of utmost importance for anyone working in the field of professional video editing. BenQ BL series offers a wonderful range of 100% sRGB monitor with a resolution of QHD and 4K2K UHD to give you crisp and clear viewing quality accompanied by true, lifelike colors. The large viewing space combined with optimal viewing prevision give video editors full access to all the editing tools, applications and images they need to work with. So they can perform every task with maximized efficiency.
  • Graphic arts
    A high-quality monitor with high resolution, high color accuracy and fidelity and a wide range of high-speed connectivity options is what makes a perfect companion for professionals in the graphic arts industry, including graphic designers, retouchers and photographers. Featuring the highest resolution at 3840x2160 4K2K with 100% sRGB and BenQ's advanced IPS technology, the BL series showcases consistent, reliable color results with every detail precisely rendered for a brilliant viewing experience from virtually every perspective. A variety of connectivity and view options also enables users to work with multiple devices and perform complex multi-tasking work with ease.
  • BenQ Proprietary Flicker-free Technology
    The BL series are newly upgraded with the incorporation of BenQ's proprietary Flicker-free Technology to eliminate backlight flickering at all brightness levels and effectively reduce eye fatigue. Conventional LCD screens flickers 200 times per second. The flickers may not be detectable by your eyes but they can certainly feel the flickering. So it is important to relieve your eyes from the stress caused by a flickering screen - and keep them nice and fresh when you are working on new designs.
BenQ BL3201PT - BL Series - LED monitor - 4K - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class C
Energy Consumption per Year
90 kWh
Power Consumption (On mode)
62 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.1845 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DVI-D, 2xDisplayPort
Speakers
Integrated
Display Position Adjustments
Pivot (rotation), swivel, tilt
74.03 cm x 21.34 cm
12.5 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class C
90 kWh
Diagonal Size
32"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.1845 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Senseye 3 Technology, Low Blue Light Mode, Flicker Free technology, CAD/CAM Mode, Auto Pivot
74.03 cm x 21.34 cm - with stand
12.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
5 Watt
DVI-D (dual link) , 2 x DisplayPort , HDMI , USB , 5 x USB 3.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x SuperSpeed USB cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x audio cable
Security Slot Type
Kensington security slot
Power Supply
Internal
62 W
Power Consumption (Typical)
79 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Apple MacOS, Microsoft Windows 7, Windows 8, Windows 8.1
Dimensions & Weight Details
Without stand - width: 74.03 cm - depth: 6.56 cm - height: 43.64 cm
Sustainability Information
ENERGY STAR Certified
B221 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
