BenQ BL3200PT 32" 2560x1440 4ms DVI-D HDMI DisplayPort Speakers IPS LED Monitor
Quicklinx: 9G7FWS00 Mfr#: 9H.LC3LB.QBE
With a 2560 x 1440 WQHD resolution and extra working space mean less scrolls for zooming in and out. Start using BenQ CAD/CAM monitor now and boost your work efficiency! Unique control device docked to the stand of every BL3200PT monitor remotely accesses the OSD menu. Low Blue Light mode, or let you assign your own set of display modes providing ultimate user flexibility. Large screen monitors usually take a noticeable amount of space on the working desk. BL 3200 is designed to save as much of your workspace as possible. Compact stand architecture enables the screen to sit at the very edge of the desk and maximize your working space and comfort.
  • 100% sRGB with VA LED display
    Every color is delivered with the finest precision in every detail and at every possible viewing angle for a great viewing experience. With a 10-bit color performance that renders more than one billion hues, every image is displayed with the richest, liveliest colors.
  • For those who have a keen eye for detail and precision
    Professional CAD/CAM engineers and designers work with extremely detailed information, making superb display clarity and color accuracy absolutely vital for ensuring design precision. BenQ's BL Series offers a number of display solutions for maximized display performance, including the CAD/CAM Mode to bring out even the smallest details to view for Pro/E, SolidWorks, AutoCad, CATIA or other CAD/CAM software. Recognizing the multi-tasking and collaborative nature of the work, thoughtful features that support a wide range of viewing options are included to ensure high productivity can be preserved while users run a number of tasks simultaneously or compare and discuss design work with colleagues.
  • Animation
    Professional animators work to breath life into moving art, making even the tiniest detail paramount to delivering lively creations. To answer the visual demands of the most sophisticated animators, BenQ BL Series monitors give you uncompromising accuracy consistency for displaying every shade of colors through a wide range of optimized image calibration settings, including the brightness-enhancing Animation Mode. There is also a multitude of viewing features incorporated into the monitors to simultaneously display all the information needed for making color adjustments. So no detail can escape the eyes of its creator!
  • Animation Mode
    To make distinguishing detailed textures in darkened areas easier, BenQ developed the Animation Mode to enhance the brightness in dark areas of the artwork - without overexposing bright areas. This allows animators to fine-tune their animation creation effortlessly.
  • 10-Level Animation Mode Adjustment
    10 levels of display brightness adjustment reveal details in darkened areas for the most precise design.
  • Video editing
    Color accuracy and a clear line of view are of utmost importance for anyone working in the field of professional video editing. BenQ BL Series offers a wonderful range of 100% sRGB monitor with a resolution of QHD to give you crisp and clear viewing quality accompanied by true, lifelike colors. The large viewing space combined with optimal viewing prevision give video editors full access to all the editing tools, applications and images they need to work with. So they can perform every task with maximized efficiency.
  • Graphic arts
    A high-quality monitor with high resolution, high color accuracy and fidelity and a wide range of high-speed connectivity options is what makes a perfect companion for professionals in the graphic arts industry, including graphic designers, retouchers and photographers. Featuring the highest resolution at 3840x2160 (QHD) with 100% sRGB and BenQ's advanced IPS technology, the BL Series showcases consistent, reliable color results with every detail precisely rendered for a brilliant viewing experience from virtually every perspective. A variety of connectivity and view options also enables users to work with multiple devices and perform complex multi-tasking work with ease.
  • Ergo monitor - HAS
    An extensive range of monitor adjustments - height, tilt, pivot, stroke and swivel - tailor your own unique working station that is best suited for your height and viewing habits with a maximum 150mm distance between the screen bottom and the base.
  • Sleek ergo-design
  • I/O ports on the side
    I/O ports on the side of the screen effortlessly bring all your content together in one convenient package. 2x USB 3.0 and SD card reader provide super-speed data transmissions.
  • Slim bezel for dual monitor setup
    The slim bezel makes the monitor look lighter and larger. In a multi-display setup with two or more units, thin bezels are less intrusive and effectively expand your work-space.
  • BenQ proprietary flicker-free technology
    The BL Series are newly upgraded with the incorporation of BenQ's proprietary Flicker-free Technology to eliminate backlight flickering at all brightness levels and effectively reduce eye fatigue. Conventional LCD screens flickers 200 times per second. The flickers may not be detectable by your eyes but they can certainly feel the flickering. So it is important to relieve your eyes from the stress caused by a flickering screen - and keep them nice and fresh when you are working on new designs.
BenQ BL3200PT - BL Series - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
75 kWh
Power Consumption (On mode)
51 W
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.276 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Pivot (rotation), swivel, tilt
Voltage
AC 90 - 264 V (50/60 Hz)
Black, glossy black
73.9 cm x 23.1 cm x 63.8 cm
13 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class B
75 kWh
Diagonal Size
32"
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.276 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
100% sRGB
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
205 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Ambient light sensor, HDCP, touch keys, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Dynamic Power Saving (DPS), Low Blue Light Mode
Black, glossy black
73.9 cm x 23.1 cm x 63.8 cm - with stand
13 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
5 Watt
VGA , DVI , DisplayPort , HDMI , 2 x USB 2.0 downstream , 2 x USB 3.0 , USB 3.0 upstream , USB
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x HDMI cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
51 W
Power Consumption (Typical)
97 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 73.9 cm - depth: 23.1 cm - height: 63.8 cm - weight: 13 kg , Without stand - width: 73.9 cm - depth: 23.1 cm - height: 43.7 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
9G7F C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
