Your basket is empty
BenQ BL2710PT 27" 2560x1440 8ms VGA DVI HDMI USB Monitor Black
Quicklinx: 925RWS00 Mfr#: 9H.LAALB.QBE
Select:
BenQ BL2710, the first tailored CAD/CAM monitor is the ultimate solution carefully designed to meet all demands of every professional working with PTC, SolidWorks, AutoCAD, Maya or other CAD/CAM software.
BenQ BL2710PT - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
36 W
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
12 ms (tr - tf); 4 ms (gray-to-gray)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
63.9 cm x 25.9 cm x 39.7 cm
8.2 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
TUV GS, EN 60950, TUV Ergo, ISO 9241-307, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class B
52 kWh
36 W
Diagonal Size
27"
Viewable Size
27"
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, H/V position, sharpness, input select, colour temperature, phase
HDCP, Eco-Mode, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, 100% sRGB colour gamut, Flicker Free technology, CAD/CAM Mode
8.2 kg
Audio
Speakers - integrated
Output Power / Channel
3 Watt
VGA , DVI-D (HDCP) , DisplayPort , Headphones , Audio line-in , 2 x USB 2.0 , 2 x USB 3.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
Power Supply
Internal
AC 90 - 264 V (47 - 63 Hz)
42 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years - on-site
5 °C
20 - 90% (non-condensing)
