BenQ BL2706HT 27"1920x1080 6ms DVI-D HDMI LED Monitor
Quicklinx: CNRNWS00 Mfr#: 9H.LG3LA.TBE
Featuring the utmost image performance of a Full HD premium IPS panel. BL2706HT delivers 27" high-resolution corporate display capability with outstanding contrast, crisp clarity, and breathtaking color performance with stylish frameless design. Designed for ergonomic solutions and eye-care comfort, the BL2706HT monitor enhances work productivity. Energy efficient displays reduce your corporate's carbon footprint, encouraging corporate social responsibility.
BenQ BL2706HT - BL Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
23 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
14 ms (typical); 6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Height, pivot (rotation)
61.67 cm x 23.96 cm x 57.12 cm
7 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class A+
33 kWh
23 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
55 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Low Blue Light Mode, Flicker Free technology, Ultra-Flexible Height Adjustment System (HAS)
61.67 cm x 23.96 cm x 57.12 cm - with stand
7 kg
Audio
Speakers
Output Power / Channel
2 Watt
VGA (HD-15) , DVI-D (dual link) (HDCP) , HDMI , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
VESA Mounting Interface
100 x 100 mm
Stand
Security Slot Type
Kensington security slot
AC 90 - 264 V (47 - 63 Hz)
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 61.67 cm - depth: 23.96 cm - height: 43.12 cm , With stand - width: 61.67 cm - depth: 23.96 cm - height: 57.12 cm - weight: 7 kg
ENERGY STAR Certified
Limited warranty - 3 years - pick-up and return
5 °C
20 - 90%
