The BL2700HT with flicker-free technology, low blue light and height adjustment stand enable you to find the best viewing angles and eyestrain from long hours of work. Never before had work been this stress-free!
Wide-viewing angles
VA panel comes with an ultra-wide viewing angle from left, right, above and below. Enjoy the flawless layering and precisely contrasted details in even the darkest images; viewing as you know it, has just gotten easier! -
Rotate screen and desktop partition with display pilot software
Auto Pivot detects the rotation of the monitor and dynamically rotates displayed content automatically. All windows will be equally portioned and displayed on the screen when clicking on the Desktop Partition icon, which allows you to compare all design works with just, one simple click. -
Slim bezel for dual monitor setup
The slim bezel makes the monitor look lighter and larger. In a multi-display setup with two or more units, thin bezels are less intrusive and effectively expand your work-space. -
Ultra-flexible height adjustment system
An extensive range of monitor adjustments - height, tilt, pivot, stroke and swivel - tailors to your unique build and viewing habits perfectly. -
Flicker-free
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. -
Low Blue Light mode
Every Monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. -
Smart Reminder
The Smart Reminder gently reminds users to take a break in a predefined time interval. The breaks not only keep users' eyes comfortable and healthy, but also ensure desirable productivity. -
Certified green
The BL2700HT is certified by internationally recognized green organizations to as a truly eco-friendly product.
- BenQ BL2700HT - BL Series - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 55 kWh
- Power Consumption (On mode)
- 37 W
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey), 12 ms (tr - tf)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 90 - 264 V (50/60 Hz)
- Black, non-glossy black
- 62.3 cm x 23 cm x 51.9 cm
- 6.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class B
- 55 kWh
- Diagonal Size
- 27"
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, Senseye 3 Technology, Low Blue Light Mode, Flicker Free technology, Ultra-Flexible Height Adjustment System (HAS), Smart Reminder
- 62.3 cm x 23 cm x 51.9 cm - with stand
- 6.3 kg
Audio
- Speakers - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI-D (HDCP) , HDMI , Headphones , Audio line-in
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Backlight Life
- 30,000 hours
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 37 W
- Power Consumption (Typical)
- 45 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 62.3 cm - depth: 23 cm - height: 51.9 cm - weight: 6.3 kg , Without stand - width: 62.3 cm - depth: 5.1 cm - height: 36.7 cm
Sustainability Information
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
