Product
Brand
BenQ BL2700HT 27" 1920x1080 8ms DVI HDMI LED Monitor
Quicklinx: B21XWS00 Mfr#: 9H.LCSLB.QBE
The BL2700HT with flicker-free technology, low blue light and height adjustment stand enable you to find the best viewing angles and eyestrain from long hours of work. Never before had work been this stress-free!
BenQ BL2700HT - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
37 W
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
12 ms (tr - tf); 4 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Black, non-glossy black
62.3 cm x 23 cm x 51.9 cm
6.3 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
Display Type
Energy Class
Class B
55 kWh
37 W
Diagonal Size
27"
Viewable Size
27"
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Senseye 3 Technology, Low Blue Light Mode, Flicker Free technology, Ultra-Flexible Height Adjustment System (HAS), Smart Reminder
62.3 cm x 23 cm x 51.9 cm - with stand
6.3 kg
Audio
Speakers - integrated
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , HDMI , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+20
Swivel Angle
360
Rotation Angle
90
Height Adjustment
120 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
Backlight Life
30,000 hours
TCO Displays 6.0
Power Supply
Internal
AC 90 - 264 V (50/60 Hz)
45 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 62.3 cm - depth: 23 cm - height: 51.9 cm - weight: 6.3 kg , Without stand - width: 62.3 cm - depth: 5.1 cm - height: 36.7 cm
ENERGY STAR Certified
B21X C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
B21X C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.02
B21X C2G 5m Select High Speed HDMI with Ethernet In Stock £16.55
B21X C2G 10m Select High Speed HDMI with Ethernet In Stock £32.25
B21X C2G 15m Select High Speed HDMI with Ethernet In Stock £43.69
B21X C2G Pro HDMI to VGA Converter In Stock £49.56
