Tailor-made to improve office worker's health, comfort and work productivity in mind, the BL2420Z boasts a sharp, robust look that calls for solid performance and efficiency. Yet a hollow neck design that keeps cords and cables organized and a base stand featuring a storage tray cleverly balance solemnity with ease of use and comfort. A matte finish further provides users a glare-free viewing experience.
Deep blacks and minimized light leakage
Enjoy the flawless layering and precisely contrasted details in even the darkest images! Free of bright spots with low light leakage, VA panels are designed to deliver naturally deeper blacks with optimum contrast performance. -
3000:1 native contrast ratio for color depth and definition
An ultra-high native contrast of 3000:1, which is five times of that of general panels, adds astonishing color depth and definition to darkened, complex images with the greatest subtlety and clarity. With a native contrast ratio this high, you can expect an infinite dynamic contrast ratio that far exceeds your expectations. -
True 8-bit color performance
An 8-bit VA panel delivers smoother and more stable color transitions by rendering a total of 16.7 million color shades simultaneously. A 6-bit panel with Advanced Frame Rate Control (AFRC) requires interpolation to display the same number of colors as a true 8-bit panel does. -
178°/178° wide-viewing angles
VA panels bring truly authentic colors and ultra-sharp details from left, right, above and below to your eyes with a wide-viewing angle of 178°/178°. Viewing, as you know it, will never be the same. -
Flicker-free
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but can certainly feel them. Free your eyes from flickers by switching to Flicker-free Monitors and let your eyes do less work. -
Ultra-flexible Height Adjustment System (HAS)
An extensive range of monitor adjustments - height, tilt, pivot, stroke and swivel - tailors to your unique build and viewing habits perfectly. -
Automatic eye-protect sensor
Ambient light levels are automatically detected to help adjust the monitor brightness throughout the day for optimized clarity and viewing comfort. -
Anti-glare display
A glare panel - whether it's caused by a direct or reflected light source - makes it a challenge for office workers to see clearly without straining their eyes. The BenQ BL2420Z VA LED monitors feature an anti-glare, matt-finish display to keep distracting reflections to a minimum, so office workers can work through their day-to-day tasks with well-improved efficiency - squint-free! -
Eco Sensor
To help reduce energy waste and CO2 emissions, the Eco Sensor feature automatically switches the monitor to Eco Mode when you step away from your computer. This also helps lower your electricity costs effectively.
- BenQ BL2420Z - BL Series - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- USB 2.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 7 ms (grey-to-grey), 12 ms (typical)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI-D, VGA, DisplayPort
- Screen Coating
- Anti-glare
- Voltage
- AC 90 - 264 V
- Black, non-glossy black
- 56.32 cm x 23.955 cm x 52.49 cm
- 7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Diagonal Size
- 23.8"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Video Bandwidth
- 205 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 6500K, 5700K
- HDCP, Eco-Mode, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Low Blue Light Mode, Flicker Free technology, Auto Pivot, Display Pilot
- 7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- 2 x USB 2.0 downstream , USB 2.0 upstream , DisplayPort , Headphones , Audio line-in , VGA , DVI-D
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 140 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - 1.5 m , 1 x USB cable - 1.5 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 90 - 264 V
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.5 Watt
- OS Required
- Apple MacOS, Microsoft Windows 7, Windows 8
Sustainability Information
- ENERGY STAR Certified
