The BL2420U, 24" 4K ultra-high-definition (UHD) resolution monitor with built-in 100% sRGB, IPS technology and exclusive CAD/CAM, animation and low blue light modes for designers to improve design efficiency.
100% sRGB with IPS technology
Every color is delivered with the finest precision in every detail and at every possible viewing angle for a great viewing experience. With a 10-bit panel that renders more than one billion hues, every image is displayed with the richest, liveliest colors. -
178°/178° ultra-wide-viewing angles
For a faithful visual display of truly authentic colors and details from virtually any perspective - left, right, above and below. -
100% sRGB with ultra-vivid IPS technology
For images that exceed the color performance of standard 72% NTSC monitors with exceptionally rich hues and vibrant tones. -
Color shift-free display
For the most consistent color definition with reduced visibility of color shift between normal and oblique viewing angles. -
CAD/CAM
Professional CAD/CAM engineers and designers work with extremely detailed information, making superb display clarity and color accuracy absolutely vital for ensuring design precision. BenQ's BL Series offers a number of display solutions for maximized display performance, including the CAD/CAM Mode to bring out even the smallest details to view for Pro/E, SolidWorks, AutoCad, CATIA or other CAD/CAM software. Recognizing the multi-tasking and collaborative nature of the work, thoughtful features that support a wide range of viewing options are included to ensure high productivity can be preserved while users run a number of tasks simultaneously or compare and discuss design work with colleagues. -
CAD/CAM mode
For clearly distinguished details in complicated object wireframes, switch on the CAD/CAM Mode to alter the monitor's color and contrast settings to view highly detailed graphic information without ever missing a line again. -
Animation mode
To make distinguishing detailed textures in darkened areas easier, BenQ developed the Animation Mode to enhance the brightness in dark areas of the artwork - without overexposing bright areas. This allows animators to fine-tune their animation creation effortlessly. -
10-level animation mode adjustment
10 levels of display brightness adjustment reveal details in darkened areas for the most precise design. -
Quarter-high-definition resolution
A 2560 x 1440 quarter-high-definition (QHD) resolution offers over 77% working space comparing with 1920 x 1080 FHD.
- BenQ BL2420U - BL Series - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class C
- Energy Consumption per Year
- 50 kWh
- Power Consumption (On mode)
- 34 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 30 Hz, HDMI2: 60 Hz, DVI: 30 Hz)
- Pixel Pitch
- 0.136 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 7 ms (grey-to-grey), 14 ms (tr - tf)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DVI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black, non-glossy black
- 56.3 cm x 23.955 cm x 52.49 cm
- 7.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class C
- 50 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.136 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 24 - 76 Hz
- Horizontal Refresh Rate
- 30 - 140 kHz
- Video Bandwidth
- 600 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Remote OSD, sRGB colour management, HDCP, Low Blue Light Mode, Flicker Free technology, CAD/CAM Mode, Auto Pivot, animation mode
- 7.1 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- DVI , 2 x HDMI , DisplayPort , Headphones , Audio line-in , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 140 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable - 1.5 m , 1 x DisplayPort cable - 1.5 m , 1 x SuperSpeed USB cable - 1.5 m , 1 x audio cable - 1.5 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 34 W
- Power Consumption (Typical)
- 58 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- OS Required
- Apple MacOS, Microsoft Windows 7, Windows 8
Sustainability Information
- ENERGY STAR Certified
