BenQ BL2420U 24" 3840x2160 7ms DVI HDMI DP USB LED Monitor Speake
Quicklinx: BSXVWS00 Mfr#: 9H. LD6LA.TBE
The BL2420U, 24" 4K ultra-high-definition (UHD) resolution monitor with built-in 100% sRGB, IPS technology and exclusive CAD/CAM, animation and low blue light modes for designers to improve design efficiency.
  • 100% sRGB with IPS technology
    Every color is delivered with the finest precision in every detail and at every possible viewing angle for a great viewing experience. With a 10-bit panel that renders more than one billion hues, every image is displayed with the richest, liveliest colors.
  • 178°/178° ultra-wide-viewing angles
    For a faithful visual display of truly authentic colors and details from virtually any perspective - left, right, above and below.
  • 100% sRGB with ultra-vivid IPS technology
    For images that exceed the color performance of standard 72% NTSC monitors with exceptionally rich hues and vibrant tones.
  • Color shift-free display
    For the most consistent color definition with reduced visibility of color shift between normal and oblique viewing angles.
  • CAD/CAM
    Professional CAD/CAM engineers and designers work with extremely detailed information, making superb display clarity and color accuracy absolutely vital for ensuring design precision. BenQ's BL Series offers a number of display solutions for maximized display performance, including the CAD/CAM Mode to bring out even the smallest details to view for Pro/E, SolidWorks, AutoCad, CATIA or other CAD/CAM software. Recognizing the multi-tasking and collaborative nature of the work, thoughtful features that support a wide range of viewing options are included to ensure high productivity can be preserved while users run a number of tasks simultaneously or compare and discuss design work with colleagues.
  • CAD/CAM mode
    For clearly distinguished details in complicated object wireframes, switch on the CAD/CAM Mode to alter the monitor's color and contrast settings to view highly detailed graphic information without ever missing a line again.
  • Animation mode
    To make distinguishing detailed textures in darkened areas easier, BenQ developed the Animation Mode to enhance the brightness in dark areas of the artwork - without overexposing bright areas. This allows animators to fine-tune their animation creation effortlessly.
  • 10-level animation mode adjustment
    10 levels of display brightness adjustment reveal details in darkened areas for the most precise design.
  • Quarter-high-definition resolution
    A 2560 x 1440 quarter-high-definition (QHD) resolution offers over 77% working space comparing with 1920 x 1080 FHD.
BenQ BL2420U - BL Series - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 30 Hz, HDMI2: 60 Hz, DVI: 30 Hz)
Pixel Pitch
0.136 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
7 ms (grey-to-grey), 14 ms (tr - tf)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
Black, non-glossy black
56.3 cm x 23.955 cm x 52.49 cm
7.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class C
50 kWh
Diagonal Size
24"
Viewable Size
23.6"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.136 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
24 - 76 Hz
Horizontal Refresh Rate
30 - 140 kHz
Video Bandwidth
600 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Remote OSD, sRGB colour management, HDCP, Low Blue Light Mode, Flicker Free technology, CAD/CAM Mode, Auto Pivot, animation mode
7.1 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
DVI , 2 x HDMI , DisplayPort , Headphones , Audio line-in , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - 1.5 m , 1 x DisplayPort cable - 1.5 m , 1 x SuperSpeed USB cable - 1.5 m , 1 x audio cable - 1.5 m
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
34 W
Power Consumption (Typical)
58 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Apple MacOS, Microsoft Windows 7, Windows 8
Sustainability Information
ENERGY STAR Certified
